What do you mean? Do you want to connect or add another tv to that cable box?
Like two TVs connected to one cable box. If so, on the back of the cable box you have three different ways to connect a tv from, through AV cable, component cables and coaxial cable.
If the main tv is connected by coaxial, the second tv can be connected thru AV or Component cables..
Hope this helps.
SOURCE: Westinghouse TV no stereo
Hi my name is Roety,
I can help you with your issue ,
Why don't you simply run the cable box and DVD stereo outputs direct to the receiver. Thats what most people do. TVs do not passthrough stereo signal very well do to DHCP compliance requirements .
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Testimonial: "A very good solution, right under my nose. Thanks!!!"
SOURCE: Connecting to HD TV
This TV has no HDMI input socket. It Has a DVI input socket. Therefore you will require an HDMI to DVI converter adapter or an HDMI to DVI cable. The DVI is video only so you will require audio cables from your Sky box (Audio L and R ) which will connect to the back left of your TV (Audio L/R sockets next to the s-video and component video connectors)
