You can actually bend the door into shape if you can see that it is warped. If the freezer hing is on that corner then you can loosen the screw on that side and push the door into place and re-tighten the screws. You need a big screwdriver and a big person to get it done. you can test the repair with a dollar bill. Slip it in and close the door. It should take a little pull to pull it out. Go all around the door like that. anywhere it slides out easily you will have an air leak..
