There is a piezo sensor behind the pad typically. This can be dislodged or damaged. FIRST check your cables and try plugging the bass into another inout and see if it will trigger that sound. If not, you will need to repair the bass pedal.
SOME pedals have a sensitivity control which is a tiny pot accessable through a hole... this too is easily damaged if wrong type screwdriver is used to adjust it.
be sure and check for a broken cable, especially near the ends.
