Question about Maytag Neptune FAV6800AW Top Load Washer
Fav6800 outer tub bearings
I do not understand what you mean by 6207-2rs bearings that you got on ebay. I have the machine apart and see the problem and would like to get these bearings. A new tub is $390.00 gasp. Thx Deb
If you are looking for these bearing 6207-2RS, they are a SKF bearing you can get them at Motion Ind. or any bearing store.
Posted on Jun 03, 2008
6ya staff
SOURCE:
I replace the motor control becouse the O L sing was lid and the problem persist what other solution do I have?? thanks for your help
There are 2 codes which you may be mis-interpreting.
OL
and
DL
DL is a door latch/lock error
OL is a different beast....
OL error means the Motor Controller has sensed an Overload.
The oL code means the motor control board is struggling to power the motor up. If it recurs after removing some clothes - usually this means a new motor control.... or worse - a new bearing.
If it were a problem with the tub floating up, the unit would spin instead of nutate.
Bearing failure in this machine is very common.
I suspect the drive shaft and bearing are the problem. The bearing and shaft are part of the outer tub.
The new outer tub with bearing cost approximately $197 dollars.
If you can get access to the shaft it may be an Emory cloth will help smooth things down so that you no longer get the OL code.
This is an ambitious do-it-yourself project... as most appliance repairmen don't understand how this machine operates.
CLICK HERE
Thanks for using FixYa
Mar 04, 2011 | Whirlpool WTW6400SW Top Load Washer
Kenmore washer OASIS errror code OL
The new outer tub with bearing W10128830 cost approximately $197 dollars.
http://media.fotki.com/1_p,srrtbrrfbdbqgkkxgtqsskgwtqkq,vi/bqkfstqqfxrqqbkwgqdxbwsqrwrtq/1/1303472/5961857/image828956817962821589img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 22, 2010 | Kenmore 22422 Top Load Washer
Kenmore washer oasis mod #110.27062601 is displaying a oL code but there is hardly anything in there, it even does it when it's empty. Any thoughts?
Apr 07, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
There is an OL error code on my Kenmore Elite Oasis HE washing machine. It seems as if the washer isn't going through its final spin cycle or something. My clothes are very wet and I've been having to...
Mar 29, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
OL code. I have removed most of the items, but it
Dec 06, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Dryer is making noise when it is running,i am trying to get it apart to find problemi cannot grt it apart
I'm sorry you are having trouble opening your dryer. As I understand it, you have a noise when the machine is running and you want to fix it. I want to help you with this.
Please look for any screws that may enter from the top into the machine. Then, pop the top, literally, pry it apart from the bottom and it will open. Remove the front ... spring clips or two screws, and maybe both. Be careful with the wires that go to the door switch.
As you remove the front, the drum will fall free from the front bearing. It is probably this front bearing (made of felt normally) that is making the noise you hear. You can clean it or probably replace it. I suggest you replace the drive belt at this time as well since you are opening the machine.
You may be able to refurbish the felt bearing but you have done a lot of work to get to this point, replace it. Get parts from a FixYa.com advertiser or a local appliance parts place or visit www.repairclinic.com
I hope this comment helps you to repair the noise you hear from your machine.
Thank you for posting your question on Fix.Ya.com
a
Nov 07, 2009 | Kenmore 73952 Gas Dryer
Kenmore Elite 110 does not spin/agitate/drain
Apr 30, 2009 | Kenmore Elite 20972
Won't spin
Apr 04, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
I get a message "oL" & the clothes are not spinning
Feb 15, 2009 | Kenmore 24032\24036 Top Load Washer
I am getting an over load code on my kenmore washing machine.
Feb 10, 2009 | Kenmore Washing Machines
Maytag Neptune FAV6800AW Top Load Washer Logo
166 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
