Hi the 116-325 error for the 3535 is a 24Volt communication error.
The 24V power supply 105E18641 is probably bad, or possibly some wires that connect them.
Whit
Item, Inc
Hi
I have never serviced machine, although its been around a while.After unplugging and waiting 5 minutes machine
reset and worked,nut problem returns a few times a day.I saw in service manual this more than likely
is the 24V LVPS.
For more details click the link given below-
https://www.contactemailssupport.com/blog/aol-error-116/
Hi dc3535 error code 116-321 what is the problem
SOURCE: Xerox DocuColor 3535 103-208 error I accidentaly
There isn't much you can do, except perhaps buy at least one new board. But those are expensive
In this case, a better solution is to call Xerox. This correction must be done by an Authorized Xerox technician, with their proprietary laptop called a PWS.
They will run the procedure called GP-10 Replacing Billing PWBs.
Whit
Item, Inc.
SOURCE: Xerox DocuColor 3535 Copier Problem
116-325 RAP An error occurred in ESS fan rotation:---------Try reset procedure:--
to correct your issue:
Simultaneously press and hold the 1, the Stop, and the Power Save buttons on the Control Panel.
If the problem persists try:
Hold the 6, the Stop, and the Power Save buttons.If still it comes again,---------
Hold the 4, the Stop, and the Power Save buttons .If still it comes again ,-------
Hold the 3, the Stop, and the Power Save buttons .If still it comes again then there is internal problem with cooling fan .The ESS fan module has to be replaced.The part number for ESS fan module is
127K32920.To order this part you can order it from online website.click this link directly to order the parts:---
http://www.iteminc.com/parts_docucolor_1632_2240.htm
this will help.Thanks.Helpmech.
