Asus will tell you to back up all saved files to an off machine flashdrive or external hard drive, then turn the unit off then turn it on go to computer and open to the search box enter manufacturers default reboot.vIt will reboot your OS from a protected boot sector on your hard drive. If this doesn't fix take it a trusted computer repair service.
SOURCE: Scroll bar on asus mouse pad not working
Try removeing any external devices and reboot the unit.
Next, look at your device manager for flags..
Remove any if shown in manager.
Restart the unit.
If you still don't have control of the scroll bar, try booting into safe mode and see if you have control their.
If you still do not have control of the scroll bar, try reloading the drivers for the mouse and touch pad.
Buy any chance do you have a mouse lock or switch on the unit that may be on.
I know, on the center of my touch pad, I have a switch to engage and dis-engagae.
SOURCE: I have an Asus K60 Laptop.I can not figure out how
Did you try the FN key and F9...
That is what they say to disable your touchpad
You have a function key which is called Fn That key allows you to use the functions on the F series keys
So Fn then F9 should do the trick
Testimonial: "Awesome! THATNK YOU!"
SOURCE: the mouse pad on my Asus Eee pc is not working.
1. Go to the following link: http://support.asus.com/download/download.aspx
2. In the "General Download" section, select "Eee Family" from the first drop-down menu.
3. Select "Eee PC" from the second drop-down menu.
4. Select "Eee PC 1000H/XP" or "Eee PC 1000H/Linux" from the third drop-down menu.
5. Click "Search".
6. In the pop-up window, select your oprating system, then click "Search".
7. On the next page, click the "+" sign oppoaite to "Touchpad". Download the latest driver version & any updates. Dates of each version are written opposite to it.
8. For each file, click on "Global (DLM)" opposite to "Download from".
9. Enter the numbers/characters in the displayed image into the text box, then click "Submit".
SOURCE: Backlit keyboard problem
dirt22man, if you didn`t solve the problem yet, press Fn+F4 . Cheers
