If the remote is not working, then disarm the alarm manually. Turn the ignition on and press and release the valet switch one time. You should hear two chirps from the alarm. Start the car. If the car starts then replace the remote battery. If the vehicle fails to start after disarming the alarm then there could several other issues. Does the vehicle attempt to start, i.e. clicking from the starter, motor tries to turn over, etc.? Does the car battery have the power to start the car?
Car
not starting or turning over indicates towards multiple possibilities. It can
be issue with battery or weak battery. But if battery checks out ok, then it
can be starter issue or faulty alternator or problem with low fuel pressure or
no spark at spark plugs due to dirty spark plugs or faulty ignition
coil or injectors getting cracked or dirty and needs to be cleaned. To
confirm the problem, the basic troubleshooting is required. Click
this link below and follow the troubleshooting:------ http://technoanswers.blogspot.in/2012/02/car-starting-issues.html --------- This will help. Thanks
