I normally CAREFULLY drill a small hole thru the centre of the brush and get it out with a hooked probe. The brass square sleeve that the brush goes into can slide out with the brush. Make sure that doesn't happen because if it does you'll be splitting the cases to get the brush holder wire back where it belongs.
SOURCE: replacing the brush
Hi DENAULTR, this is a repeat of my previous answer to your problem. It would also be helpful to have the Parts List manual on hand. If you're lacking one, you can download a PDF version Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use KSM50P (Your K5SS mixer falls within this manual), and select the first file KSM50P.pdf (438.31 KB) listed under Parts List (4) and then check to verify this matches your mixer model. Turn to pages 6 & 7, titled ?Motor And Control Parts?, which provides an exploded view for the disassembly and reassembly of your mixer?s electrical components, along with all the part names and numbers. Locate Illus No 47, Brush holder assembly that includes Illus. Nos. #28, 32, 33, 34, & 46, and Illus. No. 29, Brush & Spring assembly respectively. Make sure you orient each bruch correctly following the illustration here: The Parts List diagrams along with the picture above regarding the orientation of the brushes should get your mixer powered back up and operational. Good luck! I hope this helps. Howard, Burke, VA If this solution has been helpful to you, please rate it, thanks! -hslincoln
Testimonial: "each side also have to be the reverse of each other and then it works"
