Question about Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver
Dewalt 18v XRP Hammer drill cause battery to burn, I'm talking flames and smoke. Motor run in both direction.
    Brigadier General:
  • 4,088 Answers
I hope this drill is still under warranty as the battery is in serious trouble. As long as the motor is turning, it should not be causing the battery to do this. Hope this helps!
Posted on Sep 23, 2010
6ya staff
SOURCE:
Dewalt 18v xrp clutch slipping and electrical smoke smell in rear
Yes you can. Depending on the model of the tool it may not be the clutch causing your problem though. On some models the transmission is more likely the problem. Brushes create an ozone smell when the motor runs so that could be the smell. Does it run slow or get hot?
Jan 01, 2012 | Dewalt 18 Volt Compact Drill Kit
I bought new batteries for ,my dewalt dw958 drill and when I put the battery in, the drill ran for about 45 seconds then started to smoke and the drill died. The batteries are dewalt 18v xrp batteris
I am thinking the switch or motor is bad, check the switch first. you can locate parts at dewaltservicenet.com. Make a wiring diagram before removing anything, these parts are polarity sensitive.
Oct 28, 2011 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
My cordless drill smokes and looses power... also drains the batteries sooner than it should.... what to do, drill is about 6 years old.
replace the motor, but you might also want to look into buying a new one unless your batterys are in great shape. The motor sounds like it is burning up and therefore draining battery and smoking. Let me know if you need more assistance and if you give me the exact model number I will try and find the cost and motor number.
Mar 05, 2011 | Dewalt DC989VA XRP 3 - speed 1/2" 18v...
De Walt DW988 XRP 18v 1/2" Hammer Drill have
Depending on how much play, thats normal. The hammer feature causes that.
Jan 25, 2011 | Dewalt Drills
Motor burned out smoke came from rear of drill. replace motor?
Save the battery and charger and forget the drill. I blieve the motor woul cost you at least half price of new. Go to the dewalt replacement site to find out
Aug 16, 2009 | Dewalt 18 Volt Xrp Heavy Duty Hammer Drill...
Dewalt 18V XRP Hammer drill, stops on torque in drillpositio
The brushes might need to be replaced. You can find them on Ebay and are easily to replace.
Aug 01, 2009 | Dewalt DC927KL Heavy Duty 18 Volt Cordless...
Describe your Dewalt & 14.4V Xrp
Hello. I can help you. Your motor is producing the smoke. Before more damage is done I recommend taking it or sending it to a Dewalt sercive center.
Jul 02, 2009 | Dewalt & 14.4V Xrp Hammer Drill
Dewalt cordless drill
You have burned out the drill motor, it is shorted, the battery smoked due to a direct short, one thing I don't understand why the thermal limiter didn't trip in battery pack, I would contact manufacturer and try to get hem to buy you a new drill.
Aug 28, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
18V xrp Drill Help
The problem could be the brushes and if so it is be quit easy to replace them by pulling the drill apart and slipping the old ones out of there sleeves on the armature and slipping the new ones back in there place . you can buy these brushes at any good tool shop . all you will need is the model number of the drill which you can locate on the side case of your drill . hope this helps.
Nov 04, 2007 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver Logo
305 people viewed this question
Top Dewalt Drills Experts
Marvin
Marvin
Lance Guthrie
Lance Guthrie
Level 1 Expert
Spud Howell
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
