Question about Refrigerators
GE MODEL# GSL22JFPH BS SERIAL# DH212339 side by side The refer will cool for about a week then frost builds up in the back of the freezer behind the panel, will defrost with hair dryer , will get another week. Looked on web sites for answer best that I can understand it is a defrost problem, but there is no defrost timer in this model. The Question is do I have to replace mother board or is that a waste of money and I am getting bad advice please help if there is a defrost timer please tell me were it is located
  • 1,891 Answers
The defrost timer is built into the mother board / but before replacing it / I would ck the heater's and if bad replace them there is a newer style and also replace the defrost terminator . and if you still have the problem then repl the main board .. mm
Posted on Sep 23, 2010
  • dwierl2345 Sep 23, 2010
    Thank you will attempt will get back if problems persist
6ya staff
SOURCE:
Ge model gsl25jfpb bs not getting cold
Is it plugged in Is the compressor running ? Is it cool at all? Is there frost on the back side of the freezer wall? If there is frost on the back wall of the freezer the defrost circuit is usually the culprit there is a heater or heaters under the back panel of the freezer compartment.they might need to be replaced
Aug 01, 2014 | GE Refrigerators
GE Artica (pss26msrss) both the freezer and the refridgertor will not cool down...
Unplug and manually defrost with a hair drier because that ice you see on back wall of your freezer is a result of frost buildup behind that rear panel. Place all the frozen items in another safe place until the defrost is complete.Here is what your freezer may look like behind that rear panel. Not much cooling in freezer or fresh food section because this frost is blocking airflow.
The replacement parts for your model are the=> WR51X10042 Defrost Heater Assembly
7_12_2012_8_36_56_pm.jpgWR51X10042
And then the defrost thermostat=> WR50X10068 Defrost Thermostat
7_12_2012_8_45_50_pm.jpgWR50X10068 If you would like instructions on how to remove and replace I will be here to answer any questions you may have. How to test these parts can be found on the same page as the replacement parts, Thanks Sea Breeze
Jul 12, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
My 5 year old GE GSH22JSRSS Stainless Steel Side by Side Refrigerator recently stopped cooling. I noticed a build up of frost on the freezer, so unplugged the fridge and let the ice melt away. After this,...
The problem you describe is that your defrost circuit has failed. The fridge should stop the compressor periodically and turn on the defrost heater to melt the frost buildup. Since the frost in building up on your coils, the fan can't blow the cold air into the fridge compartment. It defrost is controlled by a module that turns on the heater. Most of these failures have to do with the defrost heating element burning out. It can be replaced by someone who has some mechanical ability.
The coil and heater is located in the back of the freezer compartment behind the panel in the back. You can obtain parts from appliance repair outlet or online like appliancepartspros.com or repairclinic.com.
Dec 07, 2010 | GE GSH22JSRSS Stainless Steel Side by Side...
I have a GE model GSL22JFPH BS refridgerater and
Then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . There is a heater for the water dispensor tube , pt # WR49X10173 , which should keep this from happening again .
Nov 18, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerator won't cool and freezer has ice build up on back.
its a defrst problem most likely the defrost thermister wr55x10025
Jun 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frost build-up freezer back wall
Hi, You will need to remove the rear panel and test the defrost heater and the bi-metal switch. The defrost heater is a very common problem with this model. You can check continuity on both the heater and bi-metal to detern which one need replaced. The bi-metal switch needs to be tested while it is could. If both of these parts prove to be ok, you will need to change the mother board.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 24, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE side by side fridge not cooling enough Freezer side was still
check see if you have frost build up in the freezer back wall you may have defrost problem
Apr 06, 2009 | GE Refrigerators
Ge refrigerator & freezer not cooling - frost build up on back wall of freezer
You probably have a bad defrost heater behind back wall of the freezer if you turn the unit off and let it defrost a fan will help speed this up the unit will run for about 2 weeks giveing you time to get a defrost heater GE have glass tube heaters and they are bad about going out good luck
Mar 31, 2009 | GE GSS23SGSSS Stainless Steel Side by Side...
GE GSL22JFPH BS refrigerator, coils icing up
I'm in the process of fixing the same problem on a GSS22JEPDWW right now. There are several parts in the defrost circuit that I can tell:
1) Defrost Heater
2) DefrostThermostat
3) Temp Sensor (Thermistor)
4) Main Control Board
I've replaced the Defrost Heater (remove back panel of freezer section - it's a stainless steel bracket that has a glass bulb in it) and it still doesn't work. The main control card provides power to the heater 4 times every 24 hrs for 25 minutes or so to defrost the evaporator coils. If all items are working, you'll see water in the drip catch at the bottom inside of the freezer compartment. Better yet, pull the refer away from the wall for 24 hrs and check if water is gathering below the plastic drain on the right rear of the refer in the pan. The water drips into a pan and the fan for the condensor coil evaporates it. Go to the www.ge.com website and look in the service section to find the parts diagram for your refer. You can then get a part number to buy the parts you need from a local parts store or the Internet.
I just bought the thermostat a few minutes ago and will try that next. Heater was $37, thermostat was $15. Sensor is about $20 and the control card is $140 (you can find on line for $95). I'm going down that path. If none of this works, it'll be in the dump in a week.
I've learned on-line GE refers are bad news. The control cards can fail repeartedly, althoough mine has worked for over 4 years. But, I won't ever buy another one since refers should last at least 15 years in my book. After $200, it doesn't pay to throw more good money after bad. I'll keep you posted on my results.
TM
Jun 25, 2008 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
GE side by Side Fridge
froggy, First check the back panel of the freezer section and see if you have a big frost build up. If so, you probably have a defrost problem, heaters more than likely. If there is no frost build-up check to see if the fan in the freezer (evaporator fan) is running. If that's ok, next would be the automatic damper. Have someone unplug the refer. Open the refer door and listen for the damper door to open when someone plugs the refer back in. If thats operational, next would be the thermistors, you would have to ohm them out to see if they are in range. Seldom is this the problem. Check these things out and get back on what you find. Catriver..post back.
Apr 03, 2007 | GE GSS20IBPWW / GSS20IBPCC Side by Side...
Refrigerators Logo
129 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
