Seiko Pulsar watch Logo
Posted on Sep 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need instructions on how to set day and date on Pulsar alarm/quartz watch.Number on back of watch is Y960-5109. Please forward instructions. Thank you, **** Redmond
Anonymous
Level 3:
President:
  • Master 2,777 Answers
  • Posted on Sep 23, 2010
Anonymous
Master
Level 3:
President:
Answers
2777
Questions
0
Helped
666342
Points
9584
Some of these can be quite a bugger to set, there are so many variates of Pulsar watches, and I'm not able to locate exact instructions for that model. However if you call Pulsar with that model number they will gladly provide a free manual for you, one you can probably even download and view, or they can email it to you directly. Please call Pulsar at 1-201-529-5730 and request the instructions.
Thanks
Tim
Instructions for a Seiko Alarm Chronograph Watch A158-5040A?
Question moved from Lands Phones category.
SEIKO - A158 5040
Digital Watch Library http://www.digitalwatchlibrary.com > DWL > seiko-a1...
SEIKO - A158 5040 - Digital. Released in 1978 Vintage Digital Watch - Brought to you courtesy of digital-watch.com.
SEIKO QUARTZ Cal. A159 Alarm Chronograph
My Retro Watches https://myretrowatches.co.uk > uploads > 2020/09
The A158 Alarm Chronograph model can be set to give a time signal ... QUARTZ. ALARM-CHRONOGRAPH. START/STOP. DATE/SELECT. STOP-ALARM. WATCH SET TIME SET LAP STOP ...
3 pages
Missing: 5040A ‎' Show results with: 5040A
Instruction ' Seiko Watch Corporation
SEIKO WATCH https://www.seikowatches.com > customerservice > ins...
Seiko is one of the few fully integrated watch manufactures. We design and develop our own movements using leading-edge technology.
tip
HOW TO SET DAY / DATE ON AN ANALOG (STEM) WATCH
mcdevito75 here, Over Forty (40) years ago, watch manufactures added, to some of their ANALOG (wind up) and almost all of their DIGITAL (button display) watches the FEATURE of the, MONTH or DAY of the WEEK and the DATE, not only was the time of day available but also the DATE which you no longer had to go searching for, it was readily available on your wrist. The PROBLEM came with SETTING the CORRECT MONTH or DAY of the week and the DATE as some MONTHS HAD 31 DAYS rather than 30 DAYS, this meant you had to CYCLE your watch at least 62 times to get to the CORRECT DATE and mant times, when you finally did reach the CORRECT DATE, the day of the week was off, meaning more CYCLES thru the 24 hours.-------- HERE is the EASY way to SET the MONTH or DAY / DATE on your QUARTZ / MECHANICAL (STEM) watch without haveing to go thru the 24 hour cycle so many, many times. Not only is this, WEAR on your fingers, you can also damage your watch with some many cycles of the 24 hours to SET the correct MONTH or DAY / DATE. ------ HERE ARE THE BASICS,---------- Your ANALOG or STEM watch either QUARTZ or MECHANICAL should have a TWO (2) position STEM we are only familiar with the ONE (1) position we use to set the TIME, there should be TWO (2) positions to the STEM. First pull out the STEM to adjust the MONTH or DAY depending on your watches display, if your watch DISPLAYs the DAY of the week, set the DAY to one (1) DAY before the DAY you want, don"t worry about the DATE (number) yet. Once you have the MONTH or DAY set, push the STEM back into the watch, NOW with a finger nail just under the STEM (usually from the back of the stem as there is more room) gently lift the STEM to it"s first position, It may take some practice so be patient, once the STEM is in it"s first position you should be able to turn the STEM to adjust the DATE (number), if so Adust the DATE (number) to ONE (1) DATE before the DATE you want, This way your watch will be adjusted to change the DAY / DATE at the correct time. Once you have the DATE (number) adjusted to ONE (1) DATE before the DATE you want, push the STEM back into the watch, NOW pull the STEM out to adjust the time, go thru the 24 hour cycle to adjust to the correct DAY DATE (number) and time of day.------------ Your QUARTZ or MECHANICAL (stem) watch is now adjusted to the correct DAY / DATE and will change at the correct hour which is generally 12--1 AM.
on Jul 09, 2010 • Watches
Invicta model 12983, how to set day on the subdial
View the instruction manuals - Invicta
invictawatch.com/service/view-the-instruction-manuals
Enter your 4 or 5 digit model number to locate your watch. RECEIVE THE NEWSLETTER SOCIAL MEDIA · Terms & Conditions Customer Service Service ...Missing: 12983 ‎subdial
Setting Time Date Invicta Watch Chronograph - SmartBargains
https://www.smartbargains.com/.../Setting-Invicta-Chronograph.html
Know how to set time, day, and date in the Invicta Watch Chronograph. ... Invicta sells several different kinds of chronograph watches, with the two main ... and the Invicta Big Date and Day chronograph - the subdials that measure seconds and ...Missing: 12983
Invicta Reserve 48mm Octane Swiss Made Quartz ...
I have a Pulsar Qartz railroad approved watch and don't know how to change day and date! Can you help me?
Hi fatmike19,
You can download the manual for your Seiko Pulsar Watch on this link. The instruction on how you will change the day and date is there.
Hope it helps.
Thank you for using Fixya.
I don't know how to set the date properly on my Tag Heuer formula 1 watch. Is there a time of the day that I should do it?
If you go to http://www.tagheuer.com/the-collection/tag-heuer-formula-1/men/quartz-chronograph/index.lbl?w=CAH1110.BA0850 , you will see a menu on the right of the screen.
Clcik on "user manual" to download the manual for your watch.
There are no instructions about setting the date apart from saying the date changes at midnight but you can advance the date by winding it past midnight. If you want to advance it more than one day, wind it back and then forward past midnight again. Repeat as many times as required until you reach the date you need.
How far back you need to wind the watch you will have to find by eaperimenting and observing when the date changes. You might hear a soft "click" when winding it backward, you can the wind it forward again.
1helpful
Have casio watch quartz alarm 100 meter and cant set day month
If you don't have the manual, You can get instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals", watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Click on "search" and the download your instructions.
Feb 14, 2010 • Watches
2answers
Setting time/date on old Seiko
With our 10 year old grandson's help, my husband was able to figure it out. Took a while, but he is now wearing his watch again!
Thanks for the follow-up.
Top Seiko Watches Experts
Paul Bade
Ngoro
Are you a Seiko Watch Expert? Answer questions, earn points and help others
