Washing Machines Logo
Posted on May 21, 2008
Fwt449gfs1 unbalanced in spin cycle
Machine seems to stay unbalanced during spin cycle. Seems to have happened all of a sudden. Instead of smooth spinning of tub, it thrashes about as if unbalanced. Wash cycle works normally.
  • Anonymous Feb 23, 2009
    Same issue. It appears that I have a few broken plastic pieces. I'm going to take the unit apart tonight.
    Did you find the cause?
  • microsys00 Mar 19, 2009
    Same issue. works ok on wash and slow spin, but with a slight noise. When it goes to high speed spin, there is a big knocking sound. I replaced both shocks, but that didn't seem to help. It might be inside the tub, between the stainless steel tub and the outside tub. Maybe a broken guidewheel? will check the Sears site for a diragram.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 16, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1077
Points
There is a three post bracket bolted to the back of the inside drum. on ours two of the three spokes are broken. looks like you have to buy whole new drum assembly. around 300 bucks
Is this right ?
Yes, usually the tub inside a washing machine will wobble to some degree to allow operation when loads are slightly unbalanced during the spin cycle.
2answers
I am having issues with my washing machine. At it's final spin it seems to be off balance and makes loud noises
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
2helpful
2answers
Whirlpool washing machine make loud noise after spin cycle quits. Noise continues until cycle winds down. Sounds like a machine gun being fired
Hello,have to tell you that most noises from a washing machine occur during the spin cycle. If you hear loud thumping noise during the spin, the load of cloth may have become unbalanced. Stop the washer and redistribute the cloths, then restart the machine. Repeat these steps if necessary.
Thanks
Maytag pav2300 spin cycle spins unbalanced and walks
I have the same problem from day one........... help
Loud noise in final spin
Verify that the inner drum isn't broken. Sopin by hand it should trun smoothly and staight.
3helpful
Knocking in washer
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
good luck.........
AWM 8163 Whirlpool washing machine
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
2answers
My whirlpool duet washer hammers very loud when it spins. The outside of the machine doesn't seem to vibrate much but it is very loud.
That is a common occurrence with dryers such as this one. Even though it sounds bad, it is harmless. If it really bothers, you can re-balance the load and it should reduce the vibration.
Noisy Spin Cycle
hi there,
No final spin
I haven't experienced that problem, but is it possible that the machine becomes unbalanced with the spinning load and then aborts the spin, so it doesn't finish? Has the machine been properly leveled during installation?
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
