Brother MFC-8440 All-In-One Laser Printer Logo
Posted on May 21, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
FAX ANSWERS AND DIALS, BUT DOESNT FININSH THE JOB
I moved the fax into another office. It rings and shows that it is recieving but does not print out the fax. It will also dial and connect when you send out a fax, but will not complete the job. I moved it back to it's original location, but it still is not working. I have also tried a couple of different phone cables.
Anonymous
Level 2:
Champion:
  • Expert 320 Answers
  • Posted on Jan 14, 2009
Anonymous
Expert
Level 2:
Champion:
Answers
320
Questions
Helped
107543
Points
394
Have you try rebooting the fax or even unstall the software and then reinstall software.
Recieve mode
Hi slickkitty
Only one press for each display,
When you press the FAX RECEIVE MODE button, the display should change each time you press. eg: AUTO, FAX ONLY
When you see the FAX ONLY, press the SET button and leave it like that. Don't try to do it when the fax rings. Do it when the fax machine is idle.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The following instruction is found in your Fax Manual.
Set the fax machine to FAX ONLY mode by
pressing {RECEIVE MODE} until the
following is displayed.
1 The display will show the number of
rings before the fax machine answers a
call in FAX ONLY mode.
2 Press {+} or {-} to change the ring
setting to 2 and press {SET}.
How to receive calls
Just leave it. When the other party sends a fax,
the fax machine will receive it automatically.
Hope this will help, if it helped you, please give a rating.
Good luck
luciana44
1helpful
Brother Fax 2820 - The phone rings on it, but the fax come
Check if the machine is set on automatic recieve.
When on manual recieve, you'll have to start recieving manualy by pressing the button.
FAX DOESNT RING WHEN RECEIVEING CANON FAX-L350
These units only ring under two circumstances. First the external phone must be attached. It has a volume slider on the phone. Second. The recieve mode must be st for Fax/Tel not anything else
Fax will not send or receive
Hi
You need to contact comcast for this issue and get a seperate phone line to which u need to plug in the allinone. This issue may exist most of the Comcast customers.
thx
1helpful
Need to change ring on fax to 3 rings. it is an hp office-jet 6110 all in one
  1. Press Menu .
  2. Press the right arrow (>) or the left arrow (<) until Advanced Fax Setup displays.
  3. Press Enter .
  4. Press the right arrow (>) or the left arrow (<) until Answer Ring Pattern displays.
  5. Press Enter
  6. Press the right arrow (>) or the left arrow (<) until the desired ring pattern displays.
    • Single rings – The fax machine answers after a single ring.
    • Double rings – The fax machine answers after a double ring.
    • Triple rings – The fax machine answers after a triple ring.
    • Double and triple – The fax machine answers after a double and triple ring.
    • All rings – The fax machine answers any ring. This is the default when not using Distinctive Ring.
  7. Press Enter .
To recieve fax on brother
Press the 'RECEIVE MODE' button on the right side of the control panel, its next to the large 'FAX START' button. Here are your options :
Select Receive Mode
MANUAL
—You must answer all calls yourself. If you hear fax tones, press
Fax Start
to begin receiving the fax, then hang up. You can use this mode with
Distinctive Ringing. (See
Distinctive Ring
, page 8-1.)
FAX ONLY
—The fax machine automatically answers every call as a fax call. You
cannot receive a voice call, but you can dial out and make a voice call.
FAX/TEL
—The fax machine automatically answers every call. If the call is a fax, it
prints the fax. If the call is not a fax, it signals you with a double-ring (ring-ring),
different from the phone company ringing, to alert you to pick up the call. If you select
this setting, you’ll need to set the Ring Delay and F/T Ring Time features (on the
following pages). If you have extension phones on the same line as the fax machine,
set Ring Delay to 4. (See
For FAX/TEL Mode Only
, page 5-5.)
TAD:ANSWER MACH.
—This is the only setting in which you can use an external
answering machine. Your telephone answering device is connected to your fax
machine, and answers every call. Once the TAD answers, the fax machine listens for
fax tones. If it detects fax tones, it prints the fax.
The TAD setting works
only
with an external telephone answering device (TAD); it
does not work with telephone company Voice Mail. Ring Delay and F/T Ring Time
do
not
work in this setting.
2answers
I HAVE A HP OFFICE 4315 ALL IN ONE PRINT.. I CANT GET FAX AUTOMATICALLY
Set to fax, ring it from another phone, what happens? Count how many times it rings before answering (if it answers)
Do you have other things attached to it?
Where is the phone line attached to socket marked line or ext?
Do you use Broadband? Has the fax got filters attached before it?
Are there other phones in the house or has the fax a dedicated line?
DONT YELL
Machine dials during phone calls
please check if the machine is set to correct answering mode i.e. TAD/FAX ?correct it if otherwise. in case it is ok please check whether the DRPD mode may not be switched off ,pls correct it.. HAPPY FAXING HEMANT GROVER
1helpful
3answers
Wont recieve fax
NVRAM init NVRAM init returns all stored parameters in NVRAM to factory default values or to a default ROM value, depending on the variable, and performs a system reset. Performing NVRAM init can cause the product to violate local telephone regulations. Reset the language and country/region after performing NVRAM init. ENWW Service-mode functions 265 NVRAM init resets the following settings and information: ● All menu settings are reset to factory default values, including fax header and company name. ● Factory settings such as formatter number, page counts, and factory paper settings are reset. ● All faxes in memory are erased. ● All speed-dials, group-dials, and phone book entries are erased. ● All localization settings, including language and country/region, are reset. To perform NVRAM init 1. Turn off the product. 2. Press and hold down the * and MENU/ENTER buttons. 3. Continue to hold down the buttons while you turn on the product. Hold the buttons through the entire power-on sequence. 4. When Permanent Storage Init. appears on the control-panel display, release the buttons. 5. When the message Language appears on the control-panel display, set the correct language and country/region. 6. Allow the product to return to Ready before using the product.
1helpful
2answers
Cannot recieve faxes
I just spoke with customer service live chat.
-press the "Fax Mode" button
-press the menu button
-The Fax menu screen will be displayed
-press down arrow button 5 times until the screen displays "Ringing and Answering."
-press the select button
-the display will show the "Ringing and Answering menu
-press down arrow button 4 times untip "Pick-up On?" is highlighted
-press the right arrow button 2 times until the screen displays "1st ring"
-press the "select" button and now "1st ring" will be set as the default.
Norman Weimar
Norman Weimar
k24674
