Sounds like the profiles are a match for sending but on some phones you need to set the phone as ready to receive the file. You should be getting a message that the PC is trying to send a file and it may ask for a pin code. You can also authorize the two devices, creating a bond that will by-pass this process. If you add your model phone, I can give more specific help.
to suit multiple usb devices
· Operating system: Windows 95/98/2000/XP/2003/NT/XP 32-bit/AMD 64-bit/2003 32-bit/AMD 64-bit
hope this helps
if these packages are not the right
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
(be precise)don't use numbers and / - you might have to try a few times to get it right
hope it helps
