The size of the battery required for a Honora watch will depend on the specific model of the watch. However, most Honora watches use a standard watch battery known as a silver oxide battery or button cell battery. The most common size used in watches is the 1.55 volt button cell battery, which is also known as the SR626SW battery or the 377 battery.
To ensure that you purchase the correct battery for your Honora watch, it's always best to refer to the owner's manual or contact Honora's customer service for more information. Additionally, many jewelers or watch repair shops will have the necessary batteries on hand and can assist with battery replacement if needed.
The size of the battery that your Emporio Armani AR-5331 watch takes will depend on the specific model of the watch. Some common sizes for watch batteries include:
CR2032: A small, coin-shaped battery that is commonly used in small electronic devices such as watches and calculators.
CR2025: A slightly smaller version of the CR2032 battery, also commonly used in watches and small electronic devices.
CR2016: An even smaller version of the CR2032 battery, also commonly used in watches and small electronic devices.
It is best to refer to the user manual or contact the manufacturer to determine the correct size battery for your Emporio Armani AR-5331 watch. Using the wrong size battery can damage the watch or cause it to function improperly.
there are two batteries inside your watch one is for analog sr621 size of battery and the other one is for the digital cr2016 size of battery, i hope this will help you.
to change the battery of fossil blue watch,just open the case back and remove the old battery,look the number size on the battery and put a new battery that same number size ,after replacing battery press the case back tight to avoid water damage !good luck
