SOURCE: Error message when installing QuickBooks 2005 to new 64 bit compu
to: niftyneeda, I also read that qb2005 is not compatable for vista, so that may be why you continue to hae problem, but is seems as though you found a way around it. I just purchased a new computer and also new qb. bestbuy.com had qb for 99.99 1/2 the store price.
SOURCE: Upgrading from Quickbooks Pro 2003 to Quickbooks 2009
I would not open up the company file in 2009. Open your 2003 Quickbooks, make a backup and then restore the back up in 2009. If you do run into problems you might want to upgrade into 2006 and then to 2009. (you will need to find someone who can do this for you if you don't have a 2006 version. I can help you with that if you need it
SOURCE: Quickbooks Pro 2008 Payroll problem
Same thing here when attempting to "send payroll data", though mine's with pro 2009. I found this KB item which indicated that I should update:
http://payroll.intuit.com/support/kb/kbitem/1009052.html
I followed the update instructions here:
http://support.quickbooks.intuit.com/support/productupdates.aspx
Even though my update status was "nothing new" for each category, I hit the "Update Now" button anyway (it was enabled, why not?). It went through the motions of updating (even though there was nothing to update). When it finished, I closed and re-opened QB, then I was able to send the payroll data. This software is far from the gold standard I thought it was going to be.
SOURCE: error message " quickbooks has encountered a problem "
1. Do you have a backup of your quickbooks from before this started happening? If yes, try opening the backed up quickbooks file.
2. Uninstall Quickbooks 2009 completely, then reinstall it and check of updates and install all of them, then try it again.
If the problem persists, please let me know so I can continue to help you. These are the first two things to try and would be the easiest solution.
Thanks for using the FixYa forums!
