Unplug your printer from the PC... Also try uninstalling and then installing the printer,if that works.However make sure that you got the right ink cartridge for that particular printer. Then check to see if the cartridge is in right and secure, if it is not secure it won't be able to print properly.
Hold the paper feed button down and turn on the power.
The printer should do a self test when you let the button go.
This will tell you if the problem is in the printer or the PC/driver.
Also check this link:-
http://laserpage.com/articles/printer_prints_blank_pages.htm
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
This means the flex cable on your samsung phone connected to the LCD has gone bad or probably just needs re-alignment. Try to open up a message and press the sides of the LCD of your cellphone assuming that the flex cable connected to the LCD is just loose. If you are able to see some text and then disappears when you depress, then this is just a loose connection.
A flex cable is a part of all mobile phones and it functions as a tool for generating pattern-matching on text. This is why you can still view ICONS, or images, but not the TEXT. This is a cheap repair/replacement so I would advice that you bring this to a cellphone repair shop.
A flex cable looks like this:
Hope this helps. Thank you for using FixYa.
You can not read any text on the display. Also the scanner leds do not turn on.
