Question about Poulan Garden
I have a Poulan Pro lawn tractor which has a 22 horse motor and a 52 inch cutting deck. It makes a whining sound all the time and it is slow to advance or go in reverse when the temperature is cool. What could be the problem?
  • 434 Answers
The hydrostatic pump is going bad. It is located in the rear end
Posted on Sep 25, 2010
6ya staff
SOURCE:
What is the diagram for steel deck installation for a poulan lawn tractor 42 " deck 14.5 hp ?
Do a search on goggle for the make model and deck size and you can see the routing diagram.
Jun 15, 2014 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
My lawn mower will not move.
Clayton I know this sounds stupid but when you sit on your seat make sure your safety switch is actually being pushed down because if it runs while brake is on the switch doesn't need to be pushed if it shuts off soons as you let off the brake sounds like it's not being pushed in or needs to be replaced seen it many times.
Jun 26, 2013 | Poulan Pro 46Inch 22 HP Yard Tractor with...
We are needing a diagram on how to put a deck belt on a 42 inch yard machine
Needing a diagram on how to put drive belt on 42" 20hp poulan pro lawn mower
Jul 23, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
I have a Poulan PRO Model PB20H42YT. It was working great when slowly I lost forwar/reverse motion; freewheel control is engaged properly.
sounds like the drive belt is off or broken, on the lawn tractors if you remove the plate, where you shift gears, you will see the belt.
Oct 29, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Poulan pro, right out ofr the box model pr625n21rh3 serial 012010m 004039. the problem is it won't cut the full width of the deck , have to overlap 3" to get full width cut????
This is a 21" mower, meaning the blade is 21" long (maybe only 20.5") and it will cut a 21" wide path of grass. Measure the width of the path that it cuts in the grass. If it is less than 21", then the mower has the wrong (too short) blade on it. It may just have a configuration of deck and wheels that make it look like it's not cutting as wide as it should.
Jul 28, 2010 | Poulan Pro 22" Self Propelled High Wheel...
Where is the oil drain plug for a poulan self propelled 22 inch 625 series mower
remove spark plug wire from plug,tip machine on its side.look under blade for a threaded plug with a square head where bottom of motor protrudes through deck.on most models you can simply tip machine over far enough to allow oil to drain out the dipstick[filler]tube.
Sep 27, 2009 | Poulan Pro " Pro" Self Propelled Mower
Garden Logo
97 people viewed this question
Top Poulan Garden Experts
roeb
dannydoesita
Marvin
Marvin
Are you a Poulan Garden Expert? Answer questions, earn points and help others
