Question about Microsoft Xbox 360 Console
The light on my power cable box is red and my xbox will not turn on!
  • 434 Answers
Power supply is bad. They are not repairable either. EBAY
Posted on Sep 25, 2010
6ya staff
SOURCE:
The power button has a blinking red light, what does this mean?
4 flashing red light = av cable not connected. double check id av cable is connected properly. try using different av cable.
3 flashing red light = hardware problem . may require repair
2 flashing red light = overheating
1 flashing red light on bottom right LED with error code = hardware failure may require repair
Jul 04, 2011 | Buck Legendary: The Box for Xbox 360
Evry time i turn my x box on the rim of lights around the on button shines red and wont out put anythik
If all lights in the ring are red, turn off the xbox and ensure all of the power and Audio/Video cables are fully inserted in both the xbox and your television.
Feb 25, 2011 | Microsoft Xbox 360 Console
The problem with our X-box is that when you turn on, a flashing red light comes on
1 red light hardware fail or minior problem 2 is for over heating 3 is death and 4 etc call microsoft at 1-800-4my-xbox befor this cheack all cables and make sure you power brick is not yellow or red it should be green when on or orange when in standby
Dec 05, 2010 | SNK Xbox 360 Arcade Console
The tv will not turn on anymore-have a blinking red light where the power green is located -is a flat screen hdtv connected to an xbox 360, tivo, and cable box. model no. 42PF9431D/37 . The cable is...
internal breaker, hopefully that xbox is plugged into a 3prong ac outlet. unplug the tv from electricity for a half hour and that circuit breaker inside should auto reset.
Dec 15, 2009 | Philips 42PF9431D/37 TV
Xbox switches on ok but no sound or vision output to tv?
If there are no red flashing lights around the power button, check your cables. The xbox doesn't like to be turned on without the A/V cable plugged in, so it might have come loose from the TV. I'd check the connecting point to the TV, and the TV settings (make sure it is set to the xbox input, and not, say, a DVD/cable box input)
The GPU (graphics chip) has been known to go bad quite easily on the xbox, but I wouldn't want to tackle repairing that unless you see the red lights blinking (which is a sure indicator that it needs to be repaired)
Nov 11, 2009 | Microsoft Xbox 360 Console
Three red lights
Follow this steps:
1. Turn off the xbox 360, disconnect the cables wait for 20 seconds reconnect the cables and turn it back on.
2. Check the light on the power supply ( The big brick that goes to your wall )
If the light is green that means the power supply is OK
If the light is Red that means the power supply needs to be replaced
3. If above steps doesn't work, you need to contact xbox customer support to get your xbox repaired
and shipping and handling will be covered.
Good Luck
Apr 03, 2009 | Microsoft Xbox 360 Console
Three red lights
Follow the steps below, Hope this helps
Dont worry shipping and handling will be covered.
Apr 03, 2009 | Microsoft Xbox 360 Elite Console
X Box 360
It might be Red ring of Death problem, You can either send your Xbox toMicrosoft and wait for 2-3 weeks till you get back your Xbox or you canfix the problem yourself with the help of a DIY fix guide.
Check out the post discussing about RROD problem here: http://www.fix-xbox360.info/2008/08/23/xbox-360-red-light-fix/
Hope it helps...
Jan 05, 2009 | Microsoft Xbox 360 Console
3 red lights and one green one in the middle HELP
how can i fix this ring of death it will not let me play the game
Jul 31, 2008 | Microsoft Xbox 360 Console
My xbox 360 power cord box messed up....
check your Audio/Video cable connection, sometimes those lights means that the plug isn't in the xbox/tv all the way
Jan 06, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
32 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
