The HD input and the DVD input on tv only has a green screen, sound is fine and with the other input we still have a picture. Just not in HD. Is it th tuner? Is it fixable?
I have the same exact problem, green screen on HD YPbPr inputs, sound is ok, and video input is ok. This after about 1.5 years of use.I have the same exact problem, green screen on HD YPbPr inputs, sound is ok, and video input is ok. This after about 1.5 years of use.
Exactly the same problem! 1.5 years of use...drat!Exactly the same problem! 1.5 years of use...drat!
AnonymousNov 30, 2008
Same problem here. Only the Component inputs are now showing up fully green
AnonymousDec 12, 2008
same damn thing when i plug in my upconvert or my xbox
AnonymousDec 17, 2008
Exactly the same problem as ahallock3. Purchased in 8/07. Video input ok, and everything else shows up green. Exactly the same problem as ahallock3. Purchased in 8/07. Video input ok, and everything else shows up green.
You can't post conmments that contain an email address.
Green screen on hdmi is normally a defective hdmi cable. 1st try a different device , like a dvd player. if same problem try dif cable. if it still does not work you have a defective signal pcb otherwise known as a main pcb.
The Tuner signal board is dead.The Tuner signal board,that the board,where the incomming broadcasting signal plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
in this case i have to know if your tuner is working fine or not.
First of all i like you to connect any external player Exp. DVD or blue-ray player if that works with audio then it is inverter board. if audio doesn't work then its main board.
Also you will find out that if dvd is working fine on your tv than your tv setting is wrong or the tunes is dead. either way if tuner is gone then you have to change the main board.
Either way let me know what went wrong i can provide you more information about what part need and where can you get it from.
Please let me know if you have any further questions or concerns.
Also rate me if you like this post.
Thanks.
is it ran through a HDMI cable?
sometimes the source is at fault or it could be a bad hdmi cable or maybe a bad hdmi port. if your using a hdmi try plugging it into another hdmi port and see if that helps
