SOURCE: zanussi aquacycle 1400 fle 1416w
Hiya Cheap6... more than likely the brushes.. which are easily checked to see if they are worn down.. otherwise its a new or RE-con motor.
Regards Faggly
SOURCE: WHERE IS THE PRESSURE SWITCH
as i remember, it is located underneath the crossbar on the top of the machine, visible when you remove the worktop
SOURCE: Zanussi F1045W Front Load
indicated low water pressure from your external supply or blocked filters in the fill hose. turn water off, remove hose and check filter in end of hose - it is just a bit of gauze. also look into the valve and clean out if needed
SOURCE: Door not locking and program reverting straight to end
initially i would replaced the door interlock then if no result the control boart could be faulty.
