Question about LG 42PC3D 42 in. Plasma Television
My LG 42 Plasma works sometimes then half the screen goes black but the right side stays perfect???
    New Friend:
Have almost the same problem left side is black with sometime blue line red lines or a whole bunch of different lines some one help please have sound and right side of tv works fine
Posted on Sep 26, 2010
6ya staff
SOURCE:
Panasonic TH-50PX70EA HAS A HALF SCREEN PERFECT BUT OTHER HALF IS LINED AND CHANGES COLOUR AND SOMETIMES GOES BLACK GETS CLOSE TO PERFECT THEN GOES LINED AGAIN PS sorry for caps
If its a Plasma it uses sustain or t con boards--sustain will usually be two--one for left side and one for right.
Only boards are sold for these sets--no individual parts--discover which board drives the right side and replace it while crossing your fingers--either it fixed the problem or you have a bad display panel (entire screen unit which is fatal from a cost point of view).
Apr 22, 2012 | JVC PD-42WV74 42 in. Plasma EDTV
I am having a problem with my picture on the top
NEED REPLACED SU BOARD Manufacturer Panasonic Part Number TXNSU1HNTU Description PC BOARD
Feb 17, 2010 | Panasonic TH-42PX75U 42 in. Plasma...
I have an LG 42" LCD tv with blurred image on half the screen
lg 42 in lcd tv power button blinks nine times before staying on and has sound but no picture
Feb 04, 2010 | LG 42LC2D 42 in. LCD HDTV
Bottom half of screen is black
its ur diaplay problem.. go for a change of new display...
Jun 30, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
I have a 42' LG plasma that has now has a 1 1/2 inch verticle stripe on the right side. It used to come and go but now rarely goes away. Any ideas?
I believe that this could be a type of "burn in". If you watch anything with a black stripe on the sides or bottom of the screen often, then this could be the problem. My suggestion is to watch things that have no black side bars for a while (>week) and see if this eliminates the problem.
Good Luck!!
Jun 11, 2009 | LG 42PC3D 42 in. Plasma Television
LG RU-42PX11 42 plasma TV has black bar
The screen does not work properly .Ribbon wire fails.
Mar 31, 2009 | LG 42PX5D 42 in. Plasma HDTV
No picture, sound ok
I have a similar issue. Sometimes the entire screen goes black and sometimes only one-half - either the top or bottom half goes black. The only solution we have found is to gently tap the TV (usually the front side) and the picture will come back for awhile. It almost seems heat related as it only goes out after the first 10 minutes of use. There must be a fix to this.
Aug 25, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
42" Philips plasma screen goes black
You have a Ysus problem. Sounds like a cold solder joint or loss connections on ysus main board.
Jun 03, 2008 | Philips 42FD9954 42 in. Plasma HDTV
Left side vertical color lined right side clear picture half screen
I solved the same problem by replacing my digital board. Cost $118.00. Been working perfectly for several months now.
Apr 06, 2008 | LG 42PX5D 42 in. Plasma HDTV
LG 42PC3D 42 in. Plasma Television Logo
1,092 people viewed this question
Ekse
RONALD CARTER JR
