SOURCE: Camera in japanese language i want in english LUMIX DMC TZ5
Select menu
Select spanner(wrench) for setup menu.
Scroll down through the menu, there are five pages of menu items on my camera! it moves to a new page when you move off the bottom.
The language option is the penultimate item - it has an icon of a head with a speech bubble.
SOURCE: PC does not recognize Lumix DMC-TZ5 as USB device
I contacted Panasonic and here is what they told me to do and it worked.
"No additional drivers are needed as it runs off the USB drivers imbedded in
your Windows OS. That being said though, it is not that the USB ports on the
front of your computer are faulty, just that they are in fact a HUB and not
the port which is located on the back of the PC. Windows does not
traditionally like reading external Hard drives (your camera becomes one when
PC connect mode is selected) through a HUB. In this case I would still
strongly recommend connecting to the back of the PC."
SOURCE: How reliable is the Panasonic/lumix
TZ5 is a fairly reliable and solid camera. It's been out for a while and there are still no known issues with it.
The ones I've been asked to repair have all been damaged due to owners' negligence (usually been dropped, had sand in lens mechanism or suffered water damage). I still haven't encountered a TZ5 which just suddenly "stopped working".
From a repairman's point of view I can say that TZ5, just as the TZ3 before it, is really really well built. It's easy to dismantle and put together. Everything is well thought of. The lens is a work of art.
Of course you need to be careful with this camera to avoid e.g. water or sand - these might kill your tz5. Sand clogs the lens easily (of course this is an issue with just about any compact camera)
I can definitely recommend it.
Hope this helps,
Raf
SOURCE: panasonic lumix DMC-TZ5 flash stopped working. Any help?
Check to see if you've accidentally turned it off. Is there an icon of a lightning bolt in a circle with a line through it on the screen?
SOURCE: When I turn on my
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
