The 0E code means the washer won't drain. It is usually a problem with something obstructing the pump, a kink in the drain line or the pump is burned out.
Hi dear.As I know there is a OE code on LG washers,if it's Check the followings.OE is drain fault.Check your machine filter there must be blockage(Coin,pin,fluff etc.)clean it.Also check for any kink on drain hose.I hope that helps.Thanks.
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation.
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
