My spider (3 spokes on the back of the drum) was cracked and
caused the drum to bounce around in the tub during the spin cycle. I bought a new drum on-line at Sears Direct
Parts for $150 plus $15 shipping. The
drum comes with spider and with the three paddles in the drum. If you are moderately handy, you can do this
repair in 4-6 hours (if you know what you're doing, and you are not a pro). A few tips, if you've done any prior maintenance on your
washer (I had previously replaced my door switch and emptied the filter twice
plus pulled a bobby pin from the front of the pump impeller), you'll be ahead
of the game. If not, a few high level
items. First, remove everything from the washer, close your water
valves and run the machine to get as much water out as possible. It does not need to go through the spin cycle
to do this. When done, unplug the
washer. The top of the washer comes off by removing the screws that
secure the top on the backside of the washer.
The top then slides back away from the control panel. The control panel is held on by several
screws, a couple on the top at the sides, and then 2 or 3 where the soap drawer
slides in. Remove these and set control
panel on top of the washer. Remove the two screws that hold in the door switch, and
remove the spring loaded ring that holds the front of the tub boot to the front
panel. The front panel comes off with 4-6 screws on the top and
bottom of the panel. You'll need to be
careful to not pull the door switch wires as they are still attached to the
front panel with a white clip. When
everything is disconnected set the front panel aside. Disconnect the small white hose that goes into the top of
the gray boot. Next in the innards of the washer, you'll need to disconnect
the drain boot (big black flexible rubber "boot" on the right front bottom of
the tub). It is held in with a clamp
that is loosened and removed with a Phillips head screwdriver. You'll also have to disconnect the small
black tube that runs down to the boot into the white cylinder on the
right-hand-side of the machine. While
you're there, you might as well remove the boot from the front of the water pump
and clean the filer of any grime, bobby pins, loose change, etc. Now, the hard parts . . . On the front of the tub is the
large black counterweight. It is held in
by 5 nuts and bolts spaced somewhat evenly around the perimeter. The counterweight is heavy (it's filled with
cement), and it will be a lot easier to get the tub and drum out of the machine
if it's lighter. To that end, also
remove the electric motor on the back of the drum by removing the large access
panel on the back of the washer. You can
pull the belt off the motor and drum pulley before or after removing the motor. The motor is held on by 3 or 4 large
screws. Don't forget to disconnect the
motor electrical connectors including the separate ground. Again, getting as much weight off of the tub
/drum assembly will make the next steps easier.
On the top back-right of the drum there is one more rubber
boot that connects the soap dispenser to the drum. Loosen this by loosening the clamp, also with
a Phillips head screwdriver. Be a little
careful here because the clamp is tough to get to and the sheet metal rear
panel is sharp. I would suggest doing
this with a thick long-sleeve shirt on so you don't cut your wrist (like I
did). Remove the plastic pins that hold the shock absorbers to the
bottom of the tub. These are at the 5
and 8 o'clock positions. Stand the shock
absorbers upright against the side of the washer enclosure to get them out of
the way. Now, the really hard part . . . Removing the drum / tub assembly. The drum / tub assembly is held in place with
two rather short and stiff springs.
There are a couple of covers that need to be removed to get access to
the springs. I removed the covers, but
reinstalled the two screws as these screws also hold the center support on the
top of the machine and the plastic soap dispenser and water valves. When I took the machine apart, I had to lay the machine first
on its left side to release the left spring.
With that said, it was still not at all easy. When the spring released, the whole washer enclosure
started to buckle. I thought I had
ruined it. I stood the machine upright,
and got the right side spring off and the enclosure almost returned to normal. I would not recommend doing it this way. Here's what I figured out and used to put the
drum back in. This was just a great idea and it worked really well. I bought a 12 inch long (or you can get two 6
inch long hooks), and hooked one end onto the end of the spring. I then placed a board on top of the washer
cabinet on the cross members and one on top of the drum so the drum would not
run into the soap assembly and water valves.
I place another board under the drum do I would not damage the water pump
on the enclosure bottom. Then (and only
then) I hooked the other end of my 12 inch hook to my small hydraulic floor
jack that I use when I rotate my car tires.
(This will work, as will a small bottle jack. If you don't have one, then get one from a
friend.) and "jacked" the spring out of the side of the cabinet, moved the jack
over a half-an-inch and released the pressure in the jack to lower the tub /drum
assembly onto the board I had placed in the bottom of the enclosure. Then I did the same on the other side. Genius!
I know, I should've taken pictures! Slide the tub / drum assembly out of the machine. I removed the drum pulley first with an Allen
key (You'll need a breaker bar, and it is right hand-threaded like
normal). The tub is split by removing
the 30 or 40 large screws. When split,
the drum simply slides out as the bearings are in the tub. The new drum simple slides in, and you might
want to add some grease to the new drum shaft and seal. Now, just do everything above in reverse, and you're done. I saved $, plus I got to spend quality time with my tools.
SOURCE: front loading washer making banging noise during last spin
mine did this and it was a broken shock. You might look at that
SOURCE: excessive vibration during spin cycle
sure..start by re leveling the unit, with a standard carpenters level.
SOURCE: My model #gltr1670aso makes loud noises during spin cycle
Usually this is due to either the drum support breaking or the back bearing being bad-neither easy to fix- or worth it. Try lifting the drum up and down, if it moves up and down they are bad. I see this a lot, and the price of repair isn't worth it. Craig
SOURCE: Excessive vibration on spin cycle.
Front loaders are prone to vibration problems. Don't want to go into the technical details of why, but it's important that they're placed on very solid surface (preferably concrete or tile), and checked that their feet have been adjusted so that the machine is level. Unfortunately, most people don't have a concrete pad for their washer. One simple option to consider is to provide dampening of the vibrations. This can be done very simply as this one fellow demonstrates. The main thing to keep in mind with this solution is that it is merely trying to dampen the vibrations. Don't be too forceful in your own solution (think lightly touching the top of a vibrating tuning fork with your finger to stop the tone).
