SOURCE: code button
SOURCE: program the RCA#rcr312 universal remote control
hold the code search buttton until light comes on then select the device you are programing and enter code
SOURCE: RCA DIRECT TV UNIVERSAL REMOTE CODE FOR SONY TV
If you have the RCR450 remote, the manual is here =>
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/rca/rcr450-manual.zip&area=other
The codes for Sony TV are 1002, 1218 listed in the back of the manual.
SOURCE: need codes for rca universal remote rcr312w. for apex tv
With your model number at hand, check the RCA website for a later code list.
If you are the exception, you might find one.
Most all remotes have a 'search' function that lets you scan through all of the available code sets but this feature will, in most cases, provide only minimal functionality such as Power, Volume and Channel.
In truth, there isn't any such thing as a 'universal' remote, including the 'learning' remotes; I have one of those and it is unable to 'learn' from either of my later sets' remotes.
At best, these should be called (honestly) 'multi-brand.'
006,007,010,011,013,016,027,
033,035,043,049,066,087,089
Programming method
[1] Press the button of the device you want to
control (for example TV).
[2] If the device turns on, press another button,
to confirm (for example CHANNEL UP)
[3] If the device you selected (TV) responds,
you will not need to program the remote.
If the device you selected (TV) does
not respond, you will need to program
the remote
There are very rare RCA remotes, with Sylvania TV can be programmed. Just try the above codes with your present RCA remote control. If it does not help, buy the above model RCA universal remote. You will get code list and all other related documents, how to programme it or so, with the device you do purchase. OK.
