Hi
The webpage here Error Codes Canon iRC2880 Code E990 0000
suggests that it is the waste toner shutter sensor which may need replacing, or the drum unit reinstalled properly.
This is just one page of a very useful printer website where by changing the drop down menus along the top of the page you can view other errors for your machine and for other models and makes. You can also use the link to get a Service Manual for your machine.
Hope this is helpful, if so would you please register that with Fixya
Cheers
press*#additional functions#. machine will display the following screen service mode level 1 . from their choose copier. Go to adjust - clear- jam history-ok. Then err history - ok. Turn the machine off and on again. Your machine should wor fine.
fixing assembly overheating, the temperature of the fixing assembly is abnormally high.
turn the machine off for some time and then on it. if it continues indicating, reset condition in service mode ( copier>function>clear>err). replace main thermistor. replace DC controller PCB.
Service Bulletin Issued by Canon Europa N.V. Copier Color HARDWARE Revised: Addition of the Affected Machines Location: Hopper Assembly Subject: Measures against E025 error due to toner leak Detail: <Symptom> The toner leaking from the toner cartridge flows onto the inside toner sensor (PS3/PS4/PS5/PS6), causing erroneous detection and E025 error (Error in the toner motor). Model: iRC2380i iRC2880 iRC2880i iRC3080 iRC3080i iRC3380 iRC3380i iRC3580 iRC3580i Ref No.: iRC3380-023 Rev. 2 (F2-T01-NO1-10097-03) Date: January, 2009 cartridge, the toner in the supply route between the toner cartridge and the hopper may leak between the gap between the toner cartridge case and the holder of the machine. <Factory Measures> The gap between the toner cartridge case and the holder of the machine is covered with the plastic sheet and the shape of the front unit cable guide on the toner sensor is changed to prevent the toner from flowing onto the toner sensor. P-1 Position where the toner cartridge is installed nside and replace the front unit cable guide into its new type. Points to Note About Service Work: When the front unit cable guide is replaced, implement periodic cleaning (every year) for the area around the photo sensor (PS3/PS4/PS5/PS6). For the affected machines or later, implement periodic cleaning (every two years) for the area around the photo sensor (PS3/PS4/PS5/PS6) and the area of toner leak [1]. Service Parts: Supply of the new part(s) will follow a normal supply pattern. P-2 GUIDE, UNIT CABLE, FRONT [2] Change Point Parts Number Description Q'ty Interchange ability Fig No. Old FC6-9380-000 GUIDE, UNIT CABLE, FRONT 1->0 N 620 New FC6-9380-010 GUIDE, UNIT CABLE, FRONT 0-> and later IR C3580 230V EUR : CZS00218 and later IR C3580I 230V EUR : CZT04670 and later IR C3580 230V : CZU00011 and later IR C3580I 230V : CZY00752 and later IR C3580I 230V AU : CZZ00857 and later IR C3080 UL 120V : DBE01554 and later IR C3080I UL 120V : DBF02861 and later IR C3080 230V EUR : DBM00294 and later IR C3080I 230V EUR : DBN10330 and later IR C3080 230V : DBT00011 and later IR C3080I 230V : DBU00714 and later IR C3080I 230V AU : DBV01085 and later IR C2550 UL 120V : DCA03694 and later IR C2380I 230V EUR : DCF16473 and later IR C2550I 230V : DCK00864 and later IR C2550I 230V AU : DCL01033 and later
How can i reflash the hard drive
