Yes you guess right. Despite that the problem might be only one relay you need to replace the whole contol board.
You can try this web page, we have fount one but is no exactly match with model number try yourself and let also
http://www.appliancepartspros.com/partse...
Thank you for your four thups up voding.
Moreover if you can not find a new control board you can remove yours and is your able do it your self or ask you nearest elecronic techincian to replace all realys that are on the control board. You will be suprised by the results. By 90% the fauld on electronic boards especialy old models are due to an overworking relay.
Thank you for your post, K!
I understand that your Frigidaire dehumidifier is continuously running and it is not collecting water. This can be caused by a dirty filter. A dirty filter can restrict air flow which will allow your dehumidifier to not pull in air. I would recommend checking your filter to make sure it is clean.
Frost on the coils within your dehumidifier will also cause your dehumidifier to stop working as well. You should check to make sure that there is not frost visible on your dehumidifier. If you do locate frost you would need to perform a manual defrost on your dehumidifier and you can do that by disconnecting power from it for at least two to three hours.
If these steps do not resolve your issue you may need to reach out to the manufacturer for a proper resolution. I hope this information is helpful to you. -Matt
Thank you.
I am not able to find a part number or even a repair parts supplier.
Can you help in that area.
I was just talking to Encompass Parts and they sent me a sketch of BHD-501, however the part I am looking for is not on the sketch.
Apparently,my unit is an orphan.
Thank you.
YOU MEAN THERE IS NO WAY TO ORDER A PART FOR THIS MACHINE.
