We have seperate accounts for counting how many copies each accout number has. i want to know how i can print a list of each account and each accounts number of copies made.
Press System/menu counter
Scroll down to User/Job accounting
Press Enter
Scroll down to job account set
Press Enter
Scroll down to Account Report
Press Enter
Select Yes
The Job accounting report is printed.
The Auditron feature is used to prevent the machine from being used by unauthorized users and also to track the total number of copies or prints produced with each account. When the total number reaches the upper limit set up by machine administrator, users cannot use the copy feature on the machine. Before resetting the machine you will want to print a usage report. Those instructions are at the bottom of these instructions.
Press the [Log In / Out] button on the Control Panel. See the Related Items below for additional information on navigating the Control Panel.
Press the [Select] button below the Display Screen to select 'System Settings.'
Use the numeric keypad on the Control Panel to enter the Administrator Login ID, then press the [Select] button to confirm.
NOTE: The default System Administrator Login ID is set to 11111. The System Administrator mode allows you to customize many settings on the machine to suit your particular requirements. The machine enters the Machine Administrator mode only when a correct System Administrator login ID is entered.
Press the [Select] button until 'Auditron Admin' is highlighted, and then press the [Enter] button on the Control Panel to confirm selection. The Auditron Administration screen will be displayed.
Press the middle [Select] button until 'Reset Acc Limit' is highlighted, and then press the [Enter] button. The 'Reset Accounts' screen will be displayed.
Press the left [Select] button to reset all accounts.
Press the middle [Select] button to cancel the request.
Press the left or middle [Select] button to perform the action. The Auditron Administration screen will be displayed.
Press the [Exit] button to return to the default screen.
Solution : How To Print Reports and Lists (Auditron / Copy Meter Report)
The Print Report / List feature allows you to print various reports and lists for each non-print job.
Press the [Machine Status] button on the Control Panel. The Machine Status screen will be displayed on the Display Screen. See the Related Items below for additional information on navigating the Control Panel.
Press the middle [Select] button below the Display Screen to display the Report / List information.
Press the [Enter] button on the Control Panel. The Print Report / List (Non-print Jobs) screen will be displayed with the options referenced in the table below.
Copy Meter
Lists the account data such the account name, the limit set for the account and the total number of copies for each account.
Press the [Select] button to scroll to highlight the required report under the appropriate column, then press [Enter].
Press the [Start] button on the Control Panel. The Report / List will print.
The copy track function only keeps track of how many B&W/Color copies/prints are made per user account. There is no record kept on the machine of actual print copy content. That is not to say they might have some other device or software program that COULD give them that information.
To Print out the Department ID Print totals: 1. Select Additional Functions on the Control Panel. 2. Select System Settings. 3. Department ID Management. 4. Select On 5. Select Print TotalsPage Totals. 6. Print List.
this should get you to the right area. I think you are asking to read the auditron accounts. This is the reset, which will allow you to see the copy count for all accounts set up.
The Auditron feature is used to prevent the machine from being used by unauthorized users and also to track the total number of copies or prints produced with each account. When the total number reaches the upper limit set up by machine administrator, users cannot use the copy feature on the machine. When the Auditron feature is enabled users need to enter a password to display the System Settings screen, or use the Copy, Fax and E-mail features on the machine.
