Epson Stylus C60 InkJet Printer Logo
Posted on Sep 28, 2010
Epson says that the printer is malfunctioning and that I should get a new one. The green light is on and neither red light is on. However the printer refuses to print or even print a nozzle check.
rajiv6089
Level 1:
New Friend:
  • Contributor 10 Answers
  • Posted on Sep 28, 2010
rajiv6089
Contributor
Level 1:
New Friend:
Answers
10
Questions
0
Helped
3729
Points
29
Epson printers are built with a print counter, the company has predefined a maximum print no. for each model, If your printer is an old one,this could be a possible reason. If both lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can restore your printer to a working condition immediately by using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
Epson Stylus CX3900 not recognizing my new ink cartridges just installed
The Epson printer won't recognize the ink cartridge when you have dried or empty ink, outdated printer drivers, ink cartridge not installed and much more. You can easily fix the Epson printer not recognize ink cartridge issue with simple steps.
·Remove and Reinstall the ink cartridge
·Check the ink cartridge
·Update printer Drivers
If your Epson printer blinks the Red or green lights, that means your printer has some other technical issue. You can fix the Epson printer lights blinking issue with these methods.
How to fix Epson Artisan 1430 printer if the red light flashing one time and the power light on green?
Whatever the fault, just replace it the cost to repair if that is even possible is more than a new model.
2answers
The red and green lights are flashing continously and it won print
The lights continually flashing indicate a paper jam or the printer being out of ink. Check/clear any paper jam and verify the ink cartidge is set correctly.
1helpful
My Epson is printing pages in code and will not stop and the green light is blinking and the red is staying on. We put in new ink cartridges today.
zark4, The green light flashing means you have print jobs waiting to be printed. Don't Turn Off The Printer When The Green Light Is Flashing ! If you have paper in the printer, the red light means you have an empty ink cartridge. Because both things are happening at the same time, here's what you need to do. First click start. Click printers and faxes. Double left click the Epson C-60 Icon. Left click Printer and click Cancel all documents and click yes, then exit. Remove and reinsert your new ink cartridges to make sure they are seated correctly. After you have done this and the printer finishes the automatic charging of the ink cartridges, the lights should be back to normal. Green light on.
Epson r220, power light flashing green, ink light red
Include the printer. Press and hold the buttons STOP, MANITENANCE ("drop") and POWER whereupon switch off feeding.
http://files.mail.ru/N287AI
Epson C60 - The green power light and middle red error light
-reseat the new cart
-clean the contacts (cart and carriage)
-try a new cart
1helpful
Green light flashing Red light on
with regards to the status of the lights., its either the cartridges that you installed is not recognized by the printer's print head or cartridges are defective.
try these steps:
if all the inks are new take them out and get an eraser and rub the small chip gently so as to clean the contacts of the chip ( don't touch it with your finger ) reinsert the cartridges in the printer and allow it to charge.
7helpful
2answers
Epson C48 red and green lights flashing alternately
Only Solution is Re-burn printer firmware.
Mahesh DG, Pune
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
