if it has a separate monitor connection on the mother board at the back, pull the graphic card and connect to the monitor to that connection
If it is a graphic card , the mother board card will run the monitor so replace the graphic card
if you do not have a plug in graphic card and that is how you have it set up take it in for a proper diagnosis as it may be the mother board is failing
if you still have 1 month warranty its best to get it sent off now to be fixed otherwise it may be rather expensive to fix yourself the graphic card is onboard the motherboard so its all in one
your power supply is at the edge, so i'd suggest going for 650W power supply. your mainboard will support the graphics card but as i said - you need better PSU
Yes if it has the port for the graphics card it will work with the onboard graphics card just make sure then that your video output is plugged into the ATI radeon and not the onboard..or it will not work correctly. if you have anymore questions just let me know and i will answer them asap.
You can not use PCI-EXPRESS graphics cards. Only AGP 2/4X Graphics Cards Supported ( 1.5V Only) You should look for This kind of Graphics cards.
I recommend , You must try changing your Motherboard with processor and buy a graphics card ( powerful one) to play these games. Otherwise You wont enjoy any of those games you mentioned.
n.b : a common PCI-E card has 16x speed where you cannot use more than 4x on your system.
mother board have a problem,if warranty is still now u sent mother board service center,my friend is same problem,he send mother board and now it is ok.
