I want to know the remote code for sansui 29" flat tv no-ctv hard rock 294-isx,which was lost and iam not able to get the right remote after trying a lot,please advice.
reset sansui tv remote control 076k0ut011 Questions ... - Fixya
www.fixya.com > Forum > Tags
...your help in advance. need code for a one for all URC-2060B06 sansui tv try these ... ...sansui tv with a RCA 704 remote control I have sansui tv and a RCA 704 remote ... URC-3021 Remote Control: How do i program this remote to a sansui tv? ... TV Remote Controls Sansui Remote eBay NEW Orion Sansui JVC LED TV ...
reset sansui tv remote control 076k0ut011 Flat Panel ... - Fixya
www.fixya.com > ... > Tags > reset sansui tv remote control 076k0ut011
Flat Panel Televisions reset sansui tv remote control 076k0ut011 questions and answers. ... ...sansui tv to program rca remote to it model # HDLCD1955C need tv code for this model ... Question about Contex 39-inch 1080p LED TV LE39D3.
? 1:00
https://www.youtube.com/watch?v=mPbRsUI0xnk
Dec 21, 2012 - Uploaded by ElectronicAdventure
Original Sansui - Orion TV Remote Control 076K0UT011 - Save $5 with ... have the New Original Remote ...
Being a technician, why couldn't you understand that the fault to your TV is with vertical sweep failure? Check its vertical output section circuit for any loose solder terminals, or damaged component/s.
The infrared sensor inside theTV might be faulty. Replace it. This component can be located just behind the infrared window at the front panel of the TV. You have to disassembe the TV to access it.
respected sir,
ihave lost my sansui model sv2902 remote hand set during shifting my house iwould like to purchase anew remote.but sho keeper asking remote code(number)
you do not have a CRT in your flat panel set.. What you might have is your color setting to high causing the bleed or your
T-con board is bad , but first turn down your color if that does not do it have a tech replace your T-con board
Problem appeared to be with the remote,as the circuit board had some white powdery deposits on it.I got some isopropyl alcohol and a brush and cleaned the board.Seems to be ok so far
Make sure Closed-Caption is turned off. Turn set on. Set Volume to Minimum. Press both Volume down on the set, and #0 button on the remote. V-Chip password should now be released. Bill
Temporarily unsolder/remove vol up/down tactil
switches on front of circuit board.They may be sending unwanted signals to the microprocessor.
Does set work normally now? 2)Try removing
batts from remote.3)PVAT! Pull chassis, Solder
any/all bad connects esp. regulator pins.4)Send in to shop for diagnosis.
