Alcatel One Touch FIRST 20 Cordless Phone Logo
Posted on May 25, 2008
Indicator light on Alcatel 4039 Flashing orange
The indicator light on an Alcatel 4039 is flashing orange. How does one turn it off?
TA
  • Anonymous Mar 13, 2014
    I need instruction manual for Alcatel 20.01
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 01, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3451
Points
5
No problem it's just a missed call indicator... press it and on the display screen it will say missed internal or external call, press the button adjacent to that and it will display the caller id of the missed call... again press the adjacent button and you will be presented with the option to delete the missed call... as soon as you have the orange light will stop flashing. On a 4019 the sequence is Orange button, 5 times up arrow until the identity of the missed caller is displayed ok, ok again to delete and then back arrow 4 times... hope this helps :-)
Orange lite flashing when burner is on
WHAT MODEL AND BRAND FURNACE DO YOU HAVE ? USUALLY THE ORANGE INDICATOR LIGHT IS SHOWING THAT FLAME IS PRESENT. USUALLY SOLID ORANGE NO FLASH . INDICATOR LAMP COLOR AND FLASH CODES FOR TROUBLESHOOTING USUALLY ON INSIDE OF ONE OF THE DOORS AND IN PAPER WORK THAT CAME WITH FURNACE.
Asus g73jh status indicator for battery flashing green/orange
the green and yellow light indicating that your battery needs replaced
Battery light flashing orange
Your battery may have Battery charge status indicator, when you press the button next to the 4 led indicators the LEDs indicate the charge status.
Also the System Battery/Charge LED indicates the battery's current operational condition.
Flashing orange indicates Battery failure.
Put phone and usb cord in the lap top to charge...it says software unsuccessful..when i tool the phoen out..and shut it down..the computer wont come back on,,and a little orange light on the side is...
HEWLETT-PACKARD Pavilion dm4-1265dx Notebook
The flashing orange light could be the indicator to tell you that your wireless adapter is working and has a connection to your routericon1.png, if you are not wireless, press the button that is flashing and it will disable your wireless connection,to turn back on press it again.
Or there is another smaller orange indicator which tells you you are runing on battey and it is in need of charge
11helpful
After changing the bulb image will not come on and solid orange light appears
Other then POWER BUTTON light there are three lights more
1. lamp indicator
2. temperature indicator
3. computer input
witch one light is flashing RED or illuminated RED with POWER BUTTON orange light.
If LAMP INDICATOR light is illuminated RED than lamp runtime has reached 1800 hours. but projector still working.
If LAMP INDICATOR light flashing RED than lamp circuit failure, or abnormal function or lamp unit is damaged. In this case projector doing the same behave just like your projector.
if TEMPERATURE indicator illuminating RED the projector still projecting and if flashing RED than turned of itself
10helpful
2answers
Power box light is blinking orange and sometime a steady red and console want come on.
Green Indicator Light:
The default indicator light is green. When the Xbox 360 power supply light is green it means that there are no problems with your power supply. However, if you are having problems and the power supply light is green, this means that the console is faulty and you need to contact Xbox 360 support.
Orange or Yellow Indicator Light
When the Xbox 360 power supply light is orange or yellow this means there is no problem with your console but the power supply can't supply it with power.
To remedy this problem, first try unplugging the Xbox 360 power supply from the console and unplug the power cord from the wall outlet. You'll also want to uplug the Xbox 360 power supply from the power cord.
Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If you are still getting an orange or yellow indicator light, then something is at fault with the Xbox 360 power supply. If this is the case, contact the Xbox 360 customer support to get a new one.
Red Indicator Light:
If the xbox 360 power supply light is red, then there is something wrong with the power supply connection. If this is the case, try the same solution as listed above of unplugging the power supply from the console, unplugging the power cord from the wall outlet and unplugging the power supply from the power cord. Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If the indicator lights are still red, then there is a fault with the power supply. If this is the case, contact customer support about getting a new one.
No Indicator Light:
If the XBox 360 power supply light is not illuminating at all, this usually means that the Xbox power supply is not connected to the wall outlet correctly. On the other hand, it might also be a fault with the power supply or the power cord.
Either way, try the same solution as listed above for the red indicator lights. If you still don't see any lights illuminated after unplugging and then reconnecting everything, you'll need to contact customer support about getting a new power supply.
Green and Orange Indicator Light:
If the indicator light is flashing green and orange, this may mean that the console does not detect the AV Pack.
Disconnect and then reconnect the Xbox AV Pack. Make sure the connections are firmly connected. Turn your Xbox back on.
If the indicator light is still flashing green and orange, try another AV pack if one is available.
If the indicator light is still flashing green and orange, you'll need to contact Miscrosoft Customer support.
Flashing Orange Indicator Light:
If your Xbox console's indicator light flashes orange, this means the internal components have overheated and the Xbox has automatically shut down to prevent damage.
Turn off the console and let it cool for at least 10 minutes.
To prevent the Xbox from overheating in the future, make sure that it's not placed in a closed cabinet or on carpet. It's best to get the Xbox elevated off the ground where the PSU can have maximum heat release.
You'll also want to make sure the Xbox is not located near a heat source like the back side of a television, computer, monitor, or other electrical device.
POWER INDICATOR LIGHT FLASHING ORANGE
This is due to your battery not accepting charge. Unfortunately a new battery is needed.
Hope this helps
2answers
BenQ MP612c projector has three orange flashing lights
you can go to the BenQ website and download a manual for your particular projector. It should tell you what the lights indicate.
4helpful
2answers
Flashing Orange Light
the flashing orange light is an indicator to tell you that your wireless adapter is working and has a connection to your router, if you are not wireless, press the button that is flashing and it will dissable your wireless connection,to turn back on press it again.
Top Alcatel Lands Phones Experts
ADMIN Andrew
ADMIN Andrew
Thomas Perkins
Thomas Perkins
Paul Katynski
Paul Katynski
Are you an Alcatel Lands Phone Expert? Answer questions, earn points and help others
