Question about Maytag 15 cu. ft. / 425 liter Upright Freezer MQU1556A
After moving to a new home, the freezer keeps tripping the breaker every few days
  • jason zeringue Oct 01, 2010
    do you have it on an extension cord ?
  • 316 Answers
My first instinct is to ask you, are you plugging this freezer into a GFI outlet, one which has a breaker switch as part of the outlet? If so, that is the culprit and not the freezer, as refrigerators and freezers will often trip this ground fault indicator because water can on occasion reach ground, which causes the breaker to trip on the outlet.
Test this by plugging the freezer into a non GFI outlet for longer than a few days. Nothing is broken and you dont need refrigerator repair service.
Posted on Oct 01, 2010
15 AMP breaker keeps tripping
do a amp check on the compressor and fans.That will tell you exactly what is overloading.
Apr 21, 2012 | Kenmore Freezers
Freezer keeps tripping breaker
Possible that it is draining a larger current and so it trips the breaker. Check if the capacitor to the motor is faulty, replace if you find it on test to consume more current and low charge.
Also the motor can be checked , the wiring to the freezer specially the GROUND connection as any leak can also trip the circuit.
Jul 18, 2011 | Silver King 1242.90 Front Breathing...
Freezer begun tripping our 20 amp breaker for some reason
ok hi there i viewed the specs for this freezer
http://www.truemfg.com/catalog/servlet/com.apsiva.servlet.HomeServlet
this unit must be plugged into a 120v outlet with a 15amp circuit breaker dedicated (nothing else should on this circuit) so all by itself. you have to check the voltage outlet where you plug in. you must have at least 115v or better (125v the most) if you have less then 115v it will cause damage. ok you went and checked all this out and everything is 15amp with 115v or better and it still trips breaker.
ok the running amps is 6.8 amps so to blow the circuit you need 15 amp which is too high.
i suggest you call a refrigeration guy because he will be able to determine if the problem is the compressor (which has a 4 year warranty with truemfg.com only in the USA) or something else. Usually but not 100% what would make a freezer like yours to blow the fuse is the compressor. if it overheats it will do this, if there is a sudden high pressure within the system it will do it, if you have a condenser fan that is not running at proper speed it will do this...
the problem cannot be pin pointed understand please... you have to babysit it, watch for changes in the refrigeration system and the running compressor amps, voltage drops ( this will cause high amps) etc...
Refrigeration is not easy and alot of tech stay away... so those who stick it out make money cause you have 2 choices: buy another one and pay big bucks to get it fixed. at least see if you can find someone to come over (for like $40 - $60) and tell you exactly whats wrong with it... whew... hope this was helpful and not confusing...sorry
Apr 03, 2010 | True 19 cu. ft. / 538 liter Commercial...
Actually, its a True T-72 refrigerator. After running for a few weeks, the unit trips the breaker and continues to do it unless I leave it off for a few days and then re-plug it in, at which point it runs...
some manufacturers use a heater in a pan for the condensate water that is generated from the defrost cycle. It is usually located near the evap and compressor area. I've even seen them under the condenser coil. Look for a heated pan. You may have a bad heater. When it goes into defrost, water enters the pan and trips the breaker as the heater may be open and water enters it shorting it to ground. Waiting a few day allows the water to evaporate out. And the process starts all over again.
I would look for this first. If this does not pan out, let me know and we can dig alittle deeper. But try to have more details.
Dec 29, 2009 | True 72 cu. ft. / 2039 liter Commercial...
What will cause door heaters to trip breaker.
You have a short some place isolate each component if you disconnect the heater and it does not trip the the breaker replace heater. caseparts.com good luck Tom
Jul 01, 2009 | Victory Freezer Freezer, Reach-In, 2 Door,...
Once in awhile, Circuit Breaker Trips
Your compressor start relay contacts may be getting loose or worn, resulting in a delayed start on the compressor.
If the start device includes a capacitor, it could be getting weak.
GFCI are not good receptacles for devices with high starting torque.
Apr 22, 2009 | Frigidaire Freezers
Tripping Breaker
I have the same proublem with mine. It doesn't do it all the time but it does happen..
Apr 13, 2008 | Hussmann Commercial Freezer DCCG-12
Maytag 15 cu. ft. / 425 liter Upright Freezer MQU1556A Logo
463 people viewed this question
Top Maytag Freezers Experts
John Tripp
John Tripp
Ismael Rodriguez...
Dennis Boxerman
Are you a Maytag Freezer Expert? Answer questions, earn points and help others
