It could be a problem with the air damper but.... I doubt it. Self-Diagnostics in the normal operation 2-1) To select this function, press Power Freeze and Power Cool buttons simultaneously for 8 seconds with an audible tone. 2-2) In the self diagnostic mode, only corresponding LED segments will be illuminated (see the check list on the next page) NO Error 01 ICE MAKER SENSOR 02 REFRIGERATOR SENSOR 03 REFRIGERATOR DEFROST SENSOR 04 REFRIGERATOR FAN ERROR 05 ICE MAKER function error 06 CoolSelect ZoneTM SENSOR 07 REFRIGERATOR DEFROST ERROR 08 EXIT-SENSOR 09 FREEZER SENSOR 10 FREEZER DEFROST ERROR 11 FREEZER FAN ERROR 12 CONDENSER FAN ERROR
Down load this manual and go to page 29 of the pdf file,
http://www.servicematters.com/maytag_library/docs/SAM0074.pdf
You will see this:
2-3) After a 30 second illumination of error signal, the system will return to the normal operation.
Note the position of the LED in the temp windows and the side that it appears on. Then see the Control panel LED legend along with the corresponding position legend listed below listed on page 30 for interpetation. This should tell you what has failed.
Make sure to read the Details of each failure on page 30 also.
This is the legend.
13 FREEZER DEFROST ERROR
Run the test and let me know what the test indicated.
Thanks for choosing FixYa.
Kelly
