I have the DTExpress IV Special. My two crash symbols only play one sound on all three zones (edge, bell, pad) and are not able to be choked. They are both PCY130SC.
My ride cymbol PCY150S plays all three zones and is able tobe choked.
I've been thru the manual to fix and have also done factory resets with no luck. Please help.
Here is a link to the manual if you don't have one:http://www.dtxperience.com/documents/Manuals/DTXPRESS_IV/DTXPRESS_IV_Owners_Manual.pdf The procedure is on page 35.
you have to make sure the red crash 1 is on the cymbal w the choke zone on it and plugged into crash one on the module. crash 2 goes in the cymbal w no choke and plugs into perc 2 on the module. also make sure the ride zones are plugged in to the corresponding zone on the module. bottom line double check all connections and reference the setup guide if u still have it. i had the same issue.
Is the 9ch snake cable correctly connected? TOM 3 should be plugged into the 4th input and TOM 1 should be plugged into the 2nd input. (1- SNARE, 2 -TOM, 3 -TOM, 4-TOM, 5-RIDE, 6-CRASH.........)
It sounds like the sensor is bad in the unit... If you have only had it a few weeks, exercise your warraaanty for replacement. Repairing the piezo sensor is NOT really a DIY project.
i dont know if this one will work, you could also search for loopb1 and hubi's midi loopback device, one of these should work.
what you have to do is use one of these programs, or something similar, to connect your midi input to the soundcard's midi wavetable or to your midi/synth/sequencing software's midi input.
also, the drum machine should be set to output to midi channel 10. make sure that your software is set to recieve on midi channel 10, if applicable.
I see pictures that show an extra device beneath the Hi-Hat and the ads mention a "stereo hi-hat controller"... on the RHH130 there is a clutch to improve the feel of the Hi Hat... I think this is what you see in some ads.
Cut and paste:
This hi-hat pad design attaches to a standard hi-hat stand. Inside of the pad is a sensor system and built-in hi-hat clutch that feels,realistic when pressed. The RHH130 also features a dual zone design consisting of pad and edge sections that offer greater dynamic realism. The pad can also produce a foot splash.
If you have a sampler, you could midi out of the DTX brain into the midi in of the sampler to trigger the sounds. If not ,try downloading KORE2 from Native Instruments onto your computer and triggering it using the above mentioned method . Midi out from your brain to Midi in on your computer. Hope this helps.
