Xerox Phaser  8500/DN Printer Logo
Posted on May 26, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The lamination paper is stuck. never went thru the other side. How do I open it and un jam it? Please help ITS THE XEROX XRX-951L laminator. I couldn't find t n your list
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 15, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
2662
Points
7
You need to use the carrier (cardboard cover) that the lamination paper comes with.. if you dont use the carrier your plastic will stick to the hot rollers... you will need to take it apart and clean out the plastic.. easy to dow hen it is cold peels off easily... pain in the neck getting it back together as the wires in the front interfere with the front screw post...
Marty Warge
Level 3:
Master:
  • Xerox Master 561 Answers
  • Posted on Jan 23, 2020
Marty Warge
Xerox Master
Level 3:
Master:
Answers
561
Questions
Helped
187880
Points
1881
So, you seem to have thought better and bought another laminator. I know that this is not very important and reading Complainterator about laminating paper is very important for me now and it must be important for you, too because it helps to avoid problems.
glassy sound
Level 2:
New Friend:
  • Expert 39 Answers
  • Posted on Jan 21, 2020
glassy sound
Expert
Level 2:
New Friend:
Answers
39
Questions
0
Helped
49154
Points
107
Never faced such an issue. Are you sure that you are doing everything correctly?
A
Anonymous
Pop it open take the top wheel off and finagle the paper out with a flathead then reassemble
1helpful
I jammed the laminating machine, so I unscrewed and opened the machine...but now I don't know how to roll out the paper? Please help me find a way to take this out without breaking the machine!
Carefully try to turn the roller one direction and then the next. If they move, you will see the feed direction the paper loaded from. Carefully move the rollers in the opposite direction letting the paper unwind. Do not force the gears. Hopefully the paper is not fused to the rollers.
How do I remove the back of my GBC laminator to remove paper that is stuck inside the unit?
First, you must take out 4 screws out of the cover on each side of the laminator , then you will see the screws that hold the back panel onto the laminator. West Laminating secs 405-324-6092
I have a xerox laminator and it will not feed
Unplug the machine. Then try to look, using a flashlight, if there are any obstacles that may interfere with the feeding. try to gently tilt the machine and try to remove any obstructions. If you can't see anything, try to force something through the feeding path and see if something is stuck in there.
If this doesn't work, them you might want to take it apart.
5helpful
2answers
A laminate and paper jam in a Gbc HeatSeal H425 Laminator
You need to loose the vertical plastic wall on the left side, and pull it up and to the left, only then you would be able to take pink rollers and metal piece away. Step by step do this (BTW, make pictures of each step if you think you will not be able to assemble it back) :
Download parts scheme here (if link is broken I can send you; write to ororeivis [at] g mail com):
http://www.gbcconnect.com/assets/docs/H425_PARTS_POUCH_LAMINATOR.pdf
Take the lid (3) off and hang it on the corner.
Next goes off (42) part.
Now focus on the left side. Take to the side part (30) with 7mm wrench. Then both parts (14) from both sides [4 in total]. Then both parts (2). Then take out screws that are holding this vertical plastic wall place. There is two screws from the outside of laminator in the bottom!
Then black roller (36) you lift up and take out by sliding to the side. Then two long black metal pieces.
Now you should be able to pull up and move to the left that vertical plastic wall on the left side of laminator. If not, try loosing some screws that are in this wall.
Be careful taking melted jammed stuff away from heating panel. Do not over-scratch it, as it is very sensitive.
floating cowboy
How doses the plastic feed through the xrx lm1910 laminator
You will need to make sure that you are using the right type of plastic. also, is the plastic the right size? Also, you need to check if you are trying to feed at all. Are you able to feed the paper?
1helpful
The unit was heated up and when I insert the laminator pouch with the document to be laminated it does not feed. it just cooks the front edge of the pouch. do I need to let the unit cool and start...
Hi, there's a seperate switch for the moter on my laminator. After the device is heated up you need to turn on the switch, so the mechanism starts to pull in the pouch.
3helpful
The sheet im laminating rolled up inside, cannot get it out
Water-based cleaners will not work with this type of adhesive. Rubbing alcohol or a citrus-based cleaner (eg, Goo-Gone) will be required.
Using a DWL-4A laminator I followed the directions my paper went in, and nothing came out the other side it must be stuck but the laminator dosent open how do I fix this?
You're lucky. My pouch won't even go in! Poor quality product and as I've had it in the box for so long before trying it, I can't even send it back!
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
