LG 37LG50 37 in. LCD HDTV Logo
Posted on Oct 02, 2010
Reset Hotel mode - LG 37LG50 37 in. LCD HDTV
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 01, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1956
Points
5
Hi, have you tried holding the TV menu and the remote menu buttons together, then selelcting menu again on remote.
  • Anonymous Mar 08, 2011
    Hold the menu button in until you get a floating DOG (Digital On screen Graphic) in one of the top corners model dependant.
    Within 5 seconds enter 1105 enter....Engineers mode with access to Hotel functions
    Hope this helps
Anonymous
Level 1:
New Friend:
  • Posted on Mar 08, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1956
Points
Hold in the menu button a DOG (digital onscreen graphic) will appear in either top right or left comers press 1105 enter Your now in engineers mode with access to the hotel facilities
Hope this helps
2answers
LG 37LG500H remove Hotel mode.
go into tv set up and turn off hotel and turn on home
Remove (not disable) Hotel Mode
Open up the menu and do a factory reset. This will make it a normal TV again.
How do i get my panasonic th37pr9u out of hotel mode....i have tried a few things i found online but no remedy has worked.
Getting out of the hotel mode is very easy. Just go get the Panasonic remote and open your tv. Go near the tv and hold down the V/- button on the television itself. Then use the remote and press the AV button for 3 times. A hidden menu on the television screen will appear. Turn off the "Hotel Mode" from the menu and exit. Do not touch anything from the hidden menu except the hotel mode. Now you can use your tv in normal mode. The remote is required to access the hidden menu so be sure your remote is working and has working or full charged battery before doing the steps above
Read more: I just purchased a Panasonic TH-37PG9U TV from a hotel and can`t get it out of hotel mode. How do I get into normal mode? But I don`t have the remo... - I just purchased a Panasonic TH-37PG9U TV from a hotel and can`t get it out of hotel mode. How do I get into normal mode? But I don t have the remote control :: Ask Me Fast at http://www.askmefast.com/I_just_purchased_a_Panasonic_TH37PG9U_TV_from_a_hotel_and_cant_get_it_out_of_hotel_mode_How_do_I_get_into_normal_mode_But_I_dont_have_the_remo-qna9315338.html#q5576553 you need your remote,this is the one you need,maybe you can find it cheaper,https://www.amazon.com/OEM-Panasonic-Remote-Control-TH-37PWD8BK/dp/B00NRHAZDU
How do I do a factory reset and master reset
Try finding a U tube video on how to get it out of hotel mode or go the the TV manufacturers website to get the operators manual for your model of TV. You may see a section on the setup menu to turn hotel mode off.
How do i get my lg32lx4dc tv out of hotel mode?
You have to enter its service mode option to release the Hotel mode. For that, you should have its 'Service Remote Control'; not the user remote control. It will be best to contact the authorized service center for LG. google.com/+GopakumarGopalan
2answers
How to reset philips TV 42hfl5860d/27
To do a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done
I bought a Panasonic 42" Plasma th-42pwd8 from a hotel. The monitor had the menu, and channel buttons disabled through "Hotel mode". It did not come with a remote. How do I unlock the buttons?
If you cannot find the remote control at all, you will need to reprogram the EPROM IC. This IC is inside the tv, with numbers starting or in between 24c02.... Please contact any qualified tehnican for further help. The IC i mentioned is programmed and at present it is locked through Hotel Mode. Also try to look RESET switch, to reset the whole unit. Thanks
1helpful
My mother purchased a new 20 in plasma. It is set
You need to go to service mode. Here how you go - use Samsung remote off the TV then press Mute-1-8-2-Power. Tv then boost up the service mode which is you could fine the line - user reset or hotel mode or both. You can press the user reset. If there is hotel mode - check it and put it OFF. Good luck
4helpful
Akai TV - Stuck in Hotel Mode
M (menu) 7935 (regular menu appears), them press 4725 (menu service appears), then search HTLSRC (position 090), then set value 032 (this value disables Hotel Mode) - TV. Now Hotel Mode is deactivated. It is verified!
M 7935 4725, go to HTLSRC (090), fix 032 - press TV. Good luck!
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
