SOURCE: bluetooth headset won't connect in Vista
I had a similar problem. First part of the solution is to disable the headset profile for the headphones. These headphones can't handle both headset and headphone profiles at the same time. Second part of the solution is to make sure that your headphones are on when you activate bluetooth on the computer. For some reason, Vista doesn't like setting up the initial connection on-the-go, so it will just act like its connected and move on. Hope this helps!
SOURCE: Motorola S9 bluetooth headphones
Try 0000 this is standard manufacturing default code for nearly any blue-tooth device that has security feature enabled and because the moto s9 as far as i can see has no way of being able to change this code it must be still at the manufactured setting
SOURCE: Can't pair TDK BT-100 headphones to my Iphone
I managed to pair the device after plugging the bluetooth headset into the USB power slot. Then I press the main button for 5 secs until the red light started flashing very rapidly and I typed in 0000 and the headset paired off with my Iphone. Good luck
SOURCE: Bluetooth pairing code for Intempo BT-01
The pairing code is 0000. Turn off your BT-01 then back on again. The blue light flashes quickly. Only during that time can you pair with it. Good luck, Andy W
SOURCE: using an opticon (hearing aid bluetooth
You could try the bluetooth generic passwords (0000 and 1234), these usually work with most devices.
