When I try to query the modem via device manager I get the following error: "The port the modem is attached to could not be opened"
When I view the modem error log i get the following:
05-26-2008 17:31:32.968 - File: C:\WINDOWS\system32\tapisrv.dll, Version 5.1.2600
05-26-2008 17:31:32.968 - File: C:\WINDOWS\system32\unimdm.tsp, Version 5.1.2600
05-26-2008 17:31:32.968 - File: C:\WINDOWS\system32\unimdmat.dll, Version 5.1.2600
05-26-2008 17:31:32.984 - File: C:\WINDOWS\system32\uniplat.dll, Version 5.1.2600
05-26-2008 17:31:32.984 - File: C:\WINDOWS\system32\drivers\modem.sys, Version 5.1.2600
05-26-2008 17:31:32.984 - File: C:\WINDOWS\system32\modemui.dll, Version 5.1.2600
05-26-2008 17:31:33.000 - File: C:\WINDOWS\system32\mdminst.dll, Version 5.1.2600
05-26-2008 17:31:33.000 - Modem type: SoftV92 Data Fax Modem
05-26-2008 17:31:33.000 - Modem inf path: oem10.inf
05-26-2008 17:31:33.000 - Modem inf section: ModemD215
05-26-2008 17:31:33.000 - Matching hardware ID: pci\ven_14f1&dev_2013&subsys_201314f1
05-26-2008 17:31:33.031 - Opening the modem device failed with error 000005aa
How can I resolve this problem.
I running Win XP Pro with Service pack 3
SOURCE: my device properties is pci/ven 8086 dev 24c6
Get the motherboard driver from the manufacturer site and run it on your pc it will surely work
80710723 Possible Port Error - Try opening ports , TCP port: 80, 443, 5223 and UDP port: 3478, 3479, 3658. or add Ps3 to DMZ
You really might want to try creating the connections again on your PS3 system on the same modem/router you are using.
Just re-configure you connection settings and see if that helps.
I have been unable to access the internet via a dial-up connection and when I query the modem via the device manager and get "port the modem is attached to could not be opened". What to do?
Windows Vista Home Premium
Windows Update installed a new driver and modem stopped to work with same error,
Attached modemlog:
07-10-2008 20:05:44.539 - Archivo: C:\Windows\system32\tapisrv.dll, versión 6.0.6001
07-10-2008 20:05:44.539 - Archivo: C:\Windows\system32\unimdm.tsp, versión 6.0.6001
07-10-2008 20:05:44.539 - Archivo: C:\Windows\system32\unimdmat.dll, versión 6.0.6000
07-10-2008 20:05:44.539 - Archivo: C:\Windows\system32\uniplat.dll, versión 6.0.6000
07-10-2008 20:05:44.539 - Archivo: C:\Windows\system32\drivers\modem.sys, versión 6.0.6001
07-10-2008 20:05:44.539 - Archivo: C:\Windows\system32\modemui.dll, versión 6.0.6001
07-10-2008 20:05:44.539 - Archivo: C:\Windows\system32\mdminst.dll, versión 6.0.6001
07-10-2008 20:05:44.539 - Tipo de módem: PCI SoftV92 Speakerphone Modem
07-10-2008 20:05:44.539 - Ruta de acceso del archivo INF del módem: oem22.inf
07-10-2008 20:05:44.539 - Sección del archivo INF del módem: Modem1
07-10-2008 20:05:44.539 - Id. de hardware que coincide: pci\ven_14f1&dev_2f30&subsys_207514f1
07-10-2008 20:05:44.585 - Error al abrir el dispositivo de módem 000005aa
I have the same problem
Same here.
Tried to send a fax, and nothing happened.
Same here.
Ran the troubleshooter, that did not help.
My computer is a Dell Dimension 8400. Device manager shows no conflicts!
The port that the modem is attached could not be opend while running query modem in vista home premium 32bit.
