397 Ben/Sher .177 air rifle - installing repair kit problem
Crosman bought out benjamin / sheridan, and they still repair just all their pump guns. The ring sounds like a piece of a pellet, the barrels are silver soldered to the bottom tube, Not lead. Also, the repair kit should not have too many parts, you can only go so far with those guns before needing special equipment to get them apart. Get a hold of Crosman and tell them that benjamin sent you a bad part. They should fix it.
I had an old Benjamin Franklin in .22 cal, it was just a brass tube with a stock and barrel. I sent it to them, to be repaired, and I wanted the .22, because I had the 5mm and the 177. So I got it back, cost $29, New barrel, in .177, soldered on, new guts, new paint, trigger, bolt, the works.. Brand new gun. I told them I wanted the brass and I wanted the .22, They said oops, sorry. I didn't complain, nice old gun. Hope this helps.
I have the same problem, when I pump it I can hear the air escaping from the barrel. I have taken it apart and put it back together 3 times now. I even tried a heavier weight oil. Still leaks air. Thanks
pump seems to be broken. It is not pumping air.
The rifle is old, approx. 20 yrs. Needs parts to get back its power. Thank You, Steve
i took my crossman 760 apart to find the problem and now i cant get it back together
my gun fell apart need help to put back together
took it apart and cant put it back together
when i pump up my crossman 766 pellet gun ,i can hear the air escaping.WHAT CAN I DO?
There are seal kits on Ebay and at crosman.com mine is in the same shape and I will be rebuilding my this week GL to you both..
Go to crosman.com or Ebay for the seal kits.. its EASY to take a part.. and here is the link for the exploded viewhttp://www.crosman.com/pdf/manuals/C760-...
