Question about Samsung HT-BD2R 7.1 Channel Blu-ray Home Theatre System Theater System
My samsung HT-TX500 does not make any sound anymore. My suspicion is subwoofer is not working because the main player unit seems ok. But I can't even get the test tone produced now. Any idea? The subwoofer got power button and I used to hear the "oomp" sound when I turned it on. Now, I don't hear any sound at all.
Hi all. Where can i order/buy a 13 pin cable (system cable) connecting the dvd player to the subwoofer? Samsung ht tx500 home theatre system.
Look in the manual for replacement part numbers - then google-it to find one.
Otherwise, I did find an ebay listing. search for "samsung subwoofer 13-pin" - 1st listing...
It looks correct, but I certainly can't guarantee it will work.
Dec 29, 2014 | Samsung Audio Players & Recorders
Aiwa subwoofer TS-WM6 has unclean scratchy sound but pot is OK.. Sound is like when a radio station is not tuned in. Faulty capacitor??
Maybe it's the amplifier board itself causing damage, it might need to be repaired by a professional or the manufacturer that owns the product. If not, you can try to troubleshoot the unit to see what's wrong.
May 12, 2017 | Aiwa TSWM6 Subwoofer
Download firmware samsung ht-q20
While "NO DISC" message appears on the display of main unit, hold the main unit's STOP button for longer than 5 seconds. "INITIALIZE" appears on the display and all settings will return to the default values.
Using the RESET function will erase all stored settings.
Dec 30, 2011 | Samsung HT-Q20 Theater System
Subwoofer output no sound...
Check to see if it is properly hooked up to the player, and if it is, then either the amplifier's LFE(Low Frequency Emitter/Subwoofer) channel has failed, or the CPU is not beginning to forward frequencies 200Hz and below to the subwoofer. At 200Hz, the subwoofer adds to the satellite speakers, an then at 110Hz and below, only the subwoofer is playing.
Feb 28, 2010 | Samsung HT-DS630T System
Protection and shut down.ht-tx35
protection error message means that your unit's fan is not working
it is a feature to keep your unit from overheating
check if there is anything blocking the fan of your unit from rotation
Jun 09, 2009 | Samsung HT-X40 System
Samsung SWA-3000 wireless receiver not linking
@Danbrazier
Your a true life saver.... thanks a million
Jan 02, 2009 | Audio Players & Recorders
Samsung HT-TX500 region free
hi there
i live in Thailand and just made my HT-TX500 region free,
this is what i did
your dvd must be off with no dvd inside
push power on wait til no disc come up then push enter
then push 84269 then push enter then wait for the dvd to turn off
wait 5 mins.then push power on and that worked for me
Dec 13, 2008 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
SWA-4000 doesn't adquire signal of HT-TX500 Home Theather
I was having poor audio from the back speakers and didn't even know it; intermittently I'd hear them jump in volume, so myself being a little adventurous, decided to push the ID set button on the back, totally losing my ilnk... after digging and playing, I figured it out:
1.) Turn off the Head (main) Unit 2.) Power on the wireless receiver, being sure it is away from routers, other BT devices, etc. 3.) Push the "ID Set" button on the back of the wireless device and hold it until the lights on its front panel flash. 4.) Point the system's remote control at the Head Unit and punch in 0135.  Its light should turn from red to blue. 5.) Perform step 3 again. 6.) Power on the head unit.
Should link up.
Might be some redundancy there, but it works :)
Also I found that after a few cycles It seemed to work better (perhaps cycled to a better channel?)
Oct 06, 2008 | Samsung SWA-4000
Samsung Series 6 TV - cannot get TV to go through Home cinema speakes
Ok, the Audio can only be transfered to the HT if it is connected via something other than the HDMI, (the HDMI is just 1 way accept for the Anynet function (which is great with the 6 series. I have the LE52-A656))
The audio can be transfered via component cables but you will get the best out of your system using an optical cable. The main reason for optical is it ability to transfer 5.1. Only problem is the Samsung does not output 5.1!! bugger!! one you have connected it via the optical too. just set the HT to D-IN and you should be goo to go! :) There maybe something i have missed but Im at work at the mo but let me know how you get on :)
Jun 15, 2008 | Audio Players & Recorders
Samsung HT-BD2R 7.1 Channel Blu-ray Home Theatre System Theater System Logo
283 people viewed this question
Top Samsung Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
