SOURCE: I have a HP 6210
I had the same problem with a HP C5280.
Solved by temporarily removing power to the memory chip which "remembers" cartridges and their expiration dates. There is an internal battery which needs to be removed or temporarily disconnected.
On the C5280 raise the lid and remove the left hand panel (There are 2 screws which require a "star" screwdriver to remove") This reveals some electrical connections at the bottom rear of the printer. There is a small red and black pair of wires in a nylon connector. Gently pull on the connector to break the connection. Now power the printer up. Remove and replace the cartridges as necessary. The error message should go away. If not, try the procedure again, removing the other connections (one is for the tri colour cartridge, one for the black).
Once you have recovered your printer, you can reconnect all the wires, replace the cover, and you are back in business.
Up yours, HP!
SOURCE: Our Australian HP PSC 1610 All-in-one uses no. 94
You can use no. 343, 344 and 348 ink with your printer.
SOURCE: With HP PSC 1610 error
Hi
If you are using original HP cartridge, and the ink got confuse. Please try to hard reset the printer.
Shut down the computer
Open the top cover of the printer and remove the ink cartridges
Close the top cover of the printer
Turn of the printer
Disconnect the communication cables from the printer
Disconnect the powe cord from the printer
Reconnect the communication cable from the printer to the computer and the power cable to the power supply source
Turn on the printer
Return the ink cartridges into the printer
And then print the calibration
Restart your computer.
If it does not help you, please let me know to give you additional solutions
SOURCE: I have a 1610 series
Hi Hp 49 is available in the UK I just looked it up on www.amazon.co.uk from about £10.00 for the small ink one and about 20 for the bigger ink capacity.
I repair printers for a living and I have not heard that the 49 was out (that said I the first person to be told) Hope this helps Ian
