My computer does not continue its boot-up process. I heard a whizzing sound coming from my CPU and I have noticed that my CD ROM is busy reading the drive. When I open the CD ROM the boot up process continue , but when I closed it the system automatically turned off. Pls help me solve this kind of problem. Thanks......
I already checked the BIOS set up and followed your instructions, but I am experiencing similar problems... Can you give me another solution for the problem.... Many Thanks...I already checked the BIOS set up and followed your instructions, but I am experiencing similar problems... Can you give me another solution for the problem.... Many Thanks...
You can't post conmments that contain an email address.
Go into your BIOS setup and see if the CDROM is the first boot up device, then C:\ drive (hard disk) then a:\ drive if you have it. The CPU should not buzz. maybe the fan has all sorts of dust all over it and is hitting the fan blades maybe one of the fan wires is hitting the blades causing the buzz. re-install your CDROM's drivers.
Turn on the machine, press F12 once the Dell splash screen is displayed, the boot menu will show up. From the Boot Menu, use up-down arrow keys on the keyboard and highlight the CD/DVD/CD-RW and press Enter.You will see another menu, select "Boot from Cd-Rom" and press enter to select it. The system will boot up from the CD-Rom. Please note that this settings is only for one time boot, once the system is restarted, the boot sequence will be restored to the previous saved settings. If you wish to set it from the Bios, enter the Bios settings by hitting F2 or Delete (should be shown at the bottom of the Dell splash screen) while you see the Dell Splash Screen. In the Bios settings menu, go to Boot options and make the changes with the boot sequence.
sounds like a bad power supply... get one from newegg.com they are easy to replace, it will only plug in to the place it is supposed to.... check wattage out put and get same or higher
Maybe you overlook to "save and exit" the settings. Also do check the connection of the cd rom or its read capability. Do check also the disc is bootable when the CPU doesn't find boot command and system on cdrom it will find to next drive.
First Make sure your cd/dvd rom detected in bios. For that First open cpu cabinet refix power cable and ide cable to harddisk. Then check your bootable recovery disk and cd/dvd rom working fine. When you power up the computer press F1 or F2 or "del" key to enter in bios . Then go to boot option and set first boot device as your cd/dvd rom then save settings and exit. Then it boot with disk . If still not boot then there may be some issue with cd/dvd rom or bootable disk. Let me know if you need more assistance. Thanks.
The CMOS cell is sited on motherbord.
Open your cpu cabinet then you find 1 square motherbord chipset .there is 1 round cell it is called cmos cell.
If you want to reset all settings of motherbord pull it for 10 minutes then all settings are defaults automatic.
Then if you wan't to boot your computer with cd rom .
Then when you power up the computer press F1 or F2 or "del" key to enter in bios.
Then go to boot option set first boot device as your cd- rom .Then save all settings and exit.
Make sure your cd rom is detected proeprly in bios .
Then put your bootable disk in cd rom so you can boot computer with cd rom.
Try another PS2 keyboard. Try a USB keyboard with a PS2 adapter. Try resetting the bios using the jumper on the motherboard. Try removing all of the dust you can from inside the case, reseating all the components and going through the process again. If you can't get it to recognize that a keyboard is installed and can't get the bios to continue despite the no keyboard error you'll have to replace the motherboard.
Disconnect devices that are connected to USB, Fire wire, parallel and serial ports, except the keyboard, the mouse anb Internet Connection.
Turn on the computer.
When the color screen with the logo appears, press the F1 key on the keyboard until Entering SETUP is displayed. (You only have a few seconds to press the F1 key before the normal startup process continues.)
Wait until the BIOS setup program opens.
Press the right arrow key to select Boot.
Press the down arrow key to select Boot Device Priority, and then press Enter on the keyboard.
Change the first boot device to CD-ROM using one of these methods:
Press the down arrow key to select the CD-ROM item. Press the + (plus) key to move the CD-ROM item up until it is the first item in the list.
Press the down arrow key to highlight the First Boot Device selection. Press the + (plus) key until CD-ROM is the selection.
Start the recovery:-
Press the Eject button on the top CD-ROM drive, and wait for the tray to open. Insert the System Recovery CD #1 and close the tray.
Press the F10 key to save the changes and exit BIOS.
With Yes selected, press Enter.
The recovery window automatically starts; wait for the onscreen instructions to display, and then follow the instructions:-
Press R, and then press the F key again.
Click yes to perform the full system recovery.
Insert the remaining CDs when directed.
When the recovery program finishes, click Restart to restart the computer.
Before the computer restarts, the CD tray ejects. Remove the CD
Return the BIOS to the previous setting
When the color screen with the logo appears, press the F1 key on the keyboard until Entering SETUP is displayed. (You only have a few seconds to press the F1 key before the normal startup process continues.) Wait until the BIOS setup program opens.
Press F5 Key to Set Default Settings in BIOS.
Select yes and press Enter.
Complete the recovery
After the computer restarts, a series of startup screens appear. Complete Microsoft Windows setup as follows:
Complete the registration process, and then reconnect the devices that were disconnected earlier.
Reinstall software that did not originally come with the computer.
Write data files that were previously saved on the backup CD or diskette you made from the hard disk.
