Posted on Oct 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Printer: HP C4599 All in One, Limited Ed Wireless Error message Printing cartridges missing or not detected. both cartridges are in the printer. This error message appeared 4 days ago, Have any idea what I can do as I need to print some stuff
Michel Smith
Level 3:
  • Master 1,218 Answers
  • Posted on Oct 05, 2010
Michel Smith
Master
Level 3:
Answers
1218
Questions
Helped
795421
Points
2925
I suggest you try to reset the printer. remove the cartridges before starting these steps.
1. Press the Power button and the Cancel button at the same time and release them. The display will show 'Enter Special Key Combo'.
2. Now press the Blue(Scan), Green(Color Copy) and Grey(Black Copy) buttons one after the other. The display will show 'Support
1helpful
Print cartridge(s) missing or not detected
If you are getting Incompatible ink cartridge error and These cartridges were replaced a year ago, I think its time you call them once again. ( 1-800-474-6836 ) and report the issue. They will ask you for the Cartridge details like part # and expiry date on the cartridge.
Regards,
Sean
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
The black cartridge is not detected or missing even though it is there HP C4599 all-in one printer
Try to clean the contact dotted points both on catridge and printer with a clean cloth or cotton swab. Insert another catridge or previously used catridge to find whether the problem is with printer or new catrige.
1helpful
2answers
Hp Photosmart C4780 won't recognize new ink cartridges
Switch off the printer and switch on again,Unclip the cartridges one by one and clip back in again this sometimes cleans out the connector pins.This has happened to me.
1helpful
My HP C6180 is caught in a start up loop...
Hi there, " Unplug the printer cable from the computer. " Unistall the printer drivers from Device manager and also unistall the all the printer appications " restart the computer " try to download drivers from the website " after installing drivers and software it will ask you to connect the printer. " then you can connect the printer and and try to Print the test page.
Print cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth. Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
2helpful
Paper jam message on HP C4599 when there is no jam
I had the same problem. I called HP and went through the steps they had asked me to go through to fix it. It took about an hour. Nothing worked. They offered me a replacement. I said no, and they offered me a $150 gift card for Staples.
1helpful
HP office jet 4215 all-in-one printer. Getting a cartridge error
Are you sure you installed the ink cartridges correctly? They should snap in and then you should be able to do a Printer Test/Align cartridges function.
Which error message is it putting out?
k24674
Grand Canyon Tech
Grand Canyon Tech
