Casio OC500 Oceanus watch Logo
Posted on Oct 04, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an OCW-M 800. I have downloaded the manual from mfg. website and cannot seem to get it to set the time for EST correctly. THis watch cost me over $500.00 and is so complicated that I fear I have paid for an expensive time piece that cannot be timed correctly. It refuses to set itself even when I put it outside my window facing the correct direction of the atomic timeset in Colorado. The website of Casio has not been helpful. Please help! Thank you!
Anonymous
Level 3:
President:
  • Master 2,501 Answers
  • Posted on Oct 04, 2010
Anonymous
Master
Level 3:
President:
Answers
2501
Questions
Helped
1291253
Points
7081
I am not American, so I am not familiar with the definition of "EST" or which of the four "city" settings is correct for you.
Having read the instructions I see that for America you have to select "USA" first and then the appropriate city, have you done this?. The list of four options covers 4 time zones, so you should be able to get the correct time for your area.
When I bought an atomic watch recently, I had to leave it overnight to catch the timekeeping signals. I see that you posted your question only 14 hours ago. How long have you had it. GIve your watch a day or so for it to latch on to the correct time.
Check that the "autoreceive" is "on".
Check that the daylight saving time (DST) is correctly set. The manuals indicate that some areas may not be using it?
Keep trying - it is nice to have a watch that is always correct!
3helpful
I have the 5022 module... It appears to have simply stopped. It receives light daily. None of the buttons seem to have any effect.
Hi mdcc2000,
No one seems to want to take a stab at this problem, possibly fearing a low rating from users with these problems. This is just a suggestion or two...anyway.
I presume you have the manual for your watch/module #5022. If not download it from here:
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw5022.pdf
I've talked with Techs from Casio and Citizen before, who have encountered problem similar to this. Usually it was a case of no display, and needing a good "kickstart" of bright light for several minutes to start the movement (even with a new battery sometimes). From your statement, I presume you have no movement of the analog hands at all.
I don't know the age of your watch, but it may needs a change of the rechargeable battery, and recycled back to factory status. It would probably be best for Casio or an authorized service center to do this. If you or someone else is going to attempt a battery change, try grounding across the positive and negative battery terminals for about 30 seconds before the new battery is installed. Make sure you are grounded as well, so as not to induce static electricity into the watch circuitry. This should help clear the memory and remove any lockups of the processor.
We've all seen our pcs and laptops lockup and require a clean reboot...many times. So, it seems this can happen to small electronic devices using battery power also.
Contact Casio at these numbers for further help:
mark_link_def.gifFor Repair support in USA at 1-800-706-2534 during regular business hours (currently Monday-Friday 9:00a.m. - 5:00pm EST, Saturday / Sunday 10:00 a.m. - 8:00 p.m.) mark_link_def.gifFor Technical support in USA at 1-800-435-7732 during regular business hours (currently Monday-Friday 9:00 a.m. - 8:00pm EST for all products, Saturday / Sunday 10:00 a.m. - 8:00 p.m) mark_link_def.gifFor Customers in Canada at 1-800-661-2274
I hope this will help point you in a direction to solve this problem. Thanks for bearing with me on this.
Regards, Bill
1helpful
How do you set the analog time on this watch (G-511D),it only has buttons on either side to adjust the time digitaly.Thank you
HI acnalius,
I presume you don't have have the manual for this watch. Your module number should be 2738, or could be 2737. The operations are the same. The settings for this watch are a little involved, so I would rather you have all the factory information for your watch, straight from the factory.
Go to this link and download the manual/user's guide in PDF format:
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2738.pdf
If you still need help contact Casio at the following numbers:
mark_link_def.gifFor Repair support in USA at 1-800-706-2534 during regular business hours (currently Monday-Friday 9:00a.m. - 5:00pm EST, Saturday / Sunday 10:00 a.m. - 8:00 p.m.) mark_link_def.gifFor Technical support in USA at 1-800-435-7732 during regular business hours (currently Monday-Friday 9:00 a.m. - 8:00pm EST for all products, Saturday / Sunday 10:00 a.m. - 8:00 p.m) mark_link_def.gifFor Customers in Canada at 1-800-661-2274 mark_link_def.gifFor Mobile Phone support at 1-800-229-1235 mark_link_def.gifFor Direct Sales at 1-800-836-8580
Setting instructions start right on page one. Let me know if I can help further. Thanks.
Regards, Bill
Where can I get an instruction manual for a columbia cl-5037 watch
mcdevito75 here, I took a fast search and came up with, www.Columbia.com Customer service # 800-622-6953 6A---6P Mon--Fri. Est. time. Hope this helps. Or you can visit a small watch repair shop in your area for a replacement Band / strap.
Hallo, i bought casio oceanus ocw 650 T and i cann not set up the time manually. All hands are on starting position 12 o clock. Can you help me, can you send me email on [email protected]? THX. GUlic...
You can get instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals", watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Click on "search" and the download your instructions.
I forgothowto set the time in both sections of th watch.
Follow this link:
http://world.casio.com/wat/download/en/manual/
Enter required details and download instructions.
Rate me, please.
3answers
Casio Oceanus Atomic Setting
I also have an OCW-M700 and found the instructions that you download from the casio website good and perhaps easier to follow than the booklet, still does need some patience and but worth it in the end because it is a great watch. The manual time/date setting can be done fairly easily once you are in 'Timekeeping mode' (page 4, bottom right). The applicable download is operation guide 4749. Good luck. Also, you probably dont want to know this but for others out there - they sell for around 600US$ in taiwan if you can find a shop that stocks the casio upper range, taipei airport normally has stock at duty free.
Jan 05, 2008 • Watches
Top Casio Watches Experts
k24674
Robert
ZJ Limited
ZJ Limited
Are you a Casio Watch Expert? Answer questions, earn points and help others
