Dell Inspiron Mini 1012 Netbook (IM1012799OBK) Logo
Posted on Oct 04, 2010
My inspiron mini 1011 producing beeping sound on start up( on the dell screen )
Gregg Errera
Level 1:
New Friend:
  • Contributor 42 Answers
  • Posted on Oct 04, 2010
Gregg Errera
Contributor
Level 1:
New Friend:
Answers
42
Questions
0
Helped
15961
Points
94
Thaat isknown as a beep code.
Does your system start up normally?
If not let me know how many beeps and I can let you know what it meens.
  • 7 more comments
  • sharmy15 Jan 23, 2011
    abnormal one beep code apart from the normal beep which we hear while powering on,is a indication of motherboard failure .....replace MOTHERBOARD.
  • Gregg Errera
    Gregg Errera Jan 23, 2011
    If that is the code for motherboard failure it probably does need replaced. Unfortunatly Dell uses the poorest quality components out there. If you decide to repair instead of replacing your computer, check to see if Asus makes a motherboard that will fit. If not I would consider replacing the system. Dell and Gateway are your bottom end computers. Next step up would be Toshiba, E- Machines or Sony. Stay with an Intel dhip AMD gets too hot and they generaly do not last as long. If you really want a good system move on up to HP\Compaq, IBM or Panasonic.
  • Anonymous May 23, 2012
    the system dose not start up after the two beep
  • Anonymous Oct 12, 2012
    mine starts but it beeps when it starts up. there is no any problem exept that continuous beep untl it finally log in..
  • Anonymous May 21, 2013
    what do 8 beeps mean?
  • Gregg Errera
    Gregg Errera Apr 21, 2019
    https://www.youtube.com/watch?v=sdLVbfhz...
  • Anonymous Apr 21, 2019
    Gregg is 9 years late to the party, sad.
    worse yet dells manual on your PC covers this 100% at Dell.com
    ever heard of Dell.com they made it.
    not youtube goons
  • Gregg Errera
    Sorry! Been dealing with health issues and haven't been on in ages!
It start beeping until XP window come up,
It could be a bad memory module. Try removing and reinstalling them. Try one module at a time to see if beeping stops . Check all other connections to make sure they are properly connected. Hope this helps.
No screen display
Check the memory modules are inserted correctly and that they both function by removing one of them and trying to boot with the other one only, being that it has two of course.
Dell inspiron mini 1010 RAM problem
Make sure you test the ram with memtest86+ in the slot that is working correctly. Also make sure you have all your ram seated correctly so you can definitely rule out the RAM as being a problem.
If you tried different memory in the same slot and it still has the problem then the ram slot is likely bad and not the ram. So if you really need to add memory then yes the motherboard would have to be replaced.
That being said however, I'm not sure the cost of replacing the motherboard would be worth it. Personally, I would save off any important info and sell as many of the good parts as I could on eBay (HDD, RAM, Screen, keyboard, battery, power cord/adapter, etc) and buy a new one.
2answers
Inspiron mini 1018 blank screen with light behind, loud beeps, strange smell
I have green screen solution where now it changed to whole black screen with some red line and produce a sound like TV Signal..I don't know everthings about repair my netbook..What should i do?
2answers
2helpful
2answers
My Dell v515w printer won't print from my Dell inspiron mini 1011---both are on wireless home network
Might need to install the driver for the printer first! If you don't have a disk with the driver, go to the manufactures web site, to their 'driver downloads/downloads/support' where you should be able to find the driver after entering your printer model information.
hope this helps!!
Hi. We have à Dell
I would run a Check disk utility to check for errors in system files. Try running Scandisk or CHKDSK/F if they are loaded, if not go online and download CheckDisk,exe. Make sure it is for your OS otherwise it may not work properly.
Hope that helps.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
