I have an LG Split room air con, HS-C1264F72. I have run it through the night for the last 4 months (normally 7-8 hours at 22C) All of a sudden one night, I was woken to dripping water coming out of the unit. Please help?
No, Im in Malaysia. Daytime normally 32-35, NIght time normally 23-25 celcius. It never really changes. It may of dropped to 20-21 but certainly no lower than that.No, Im in Malaysia. Daytime normally 32-35, NIght time normally 23-25 celcius. It never really changes. It may of dropped to 20-21 but certainly no lower than that.
You can't post conmments that contain an email address.
There are two problems in your a/c. 1. Smell. 2. over freezing. The solution is 1.service the unit completely. 2. replace the room thermostat sensor. Sometimes, the room sensor may be working alright after servicing the unit. All the best.
Reset everythings to factory setting,Same promblems continue.Than ur main tuner signal board is the cause must change.Or call warenty for repair,factory waranty is one year.
Gas has leaked from inner or outer unit kindly get it checked by service men they will find the leak and charge the gas again normally after some time it gets rusty inside as water is involved and got leak
first check to make sure that the indoor unit is very slightly off level sloped to the drain area also turn off power and inspect the indoor coil with a flash light to make sure all the fin area is open the drain pan has two possible drain connections if they are both hooked up then the primary "lowest"
could be stoped up a blast of water or air to the drain line should clear out slime also make sure their is a trap in the drain line or the water will only drain dwhen unit is off hope this solves your problem thanks
