Belt is on, drain tube is clear, drum will move for washing, water will drain but after that it will not spin. Have to take out soaking wet clothes & put in dryer. Have had machine only 1 1/2 year. It just stopped spinning. Not heavily used? Any one have the answer to this?
I have the same washer and it will wash and drain but not spin. I replaced the door switch and the problem was solved.
Try not overloading it because that happened to me too so I took some of the clothes out and tried spinning again and it worked. It's fine now.
Check the Coin Trap and drain hose. If it Can't drain it won't spin. I get socks and thongs stuck in mine regularly. Removing the obstruction fixes the problem.
The washer data sheet for the model # LTF2940ES3
shows that error code E47 says board thinks the PTCcircuit is open in spin . Remove doorlock assembly and check the resistance of PTC if shorted or open then assembly is defective. If the resistance is around 1,500 oohms then control board is defective
Mine was doing same thing just had repair guy out door lock not completely locking which in turn is shorting out control panel some kind of bs anyway repair cost 417.00 his visit 65.00 im going out to by a new one instead just about the same price . he said something to do with door lock more amps then control panel can handle and some how shorting it out sounds like they need to do a recall or fix it for free cause i have only had mine about 2 years
The motor may be having issues turning, or it shorts out due to the water, i'd suggest checking that it is seald and nothing has burnt out
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Washer will turn during cycle and drain but will not final spin
Drum rotates fine during wash and rinse cycles but will not final spin. No error codes but 3 beeps. Removed hose, no obstructions, drains fine
I am having the same problem, washer runs fine just will not spin.
Problem is similar to what was previously described. The spinning step does not go its full cycle,which leaves
water sitting inside the washer,after the spin step.
same problem after 2 years.
I don't overload my machine. It does agigtate, but it doesn't drain or spin with clothes inside of it. I purchased this machine in Feb. 2008.
