Good Morning bigred140, thank you for allowing me to assist you!
From what you have described, it seems like you may be referring to the perimeter hot tube. It is normal to be warm to the touch; however, since it may feel hot to you, I would suggest verifying that you have the proper clearances around your refrigerator. You can refer to your owner's guide for those specifications. If you do not have an owner's guide, you can typically locate one on the manufacturer site.
If the clearance is fine, you may need to clean the condenser coils. As part of routine maintenance, you can remove the toe grille (located at the foot of your freezer) by unsnapping the sides and lifting outward towards you. Now, using an extended vacuum attachment and condenser cleaning brush, remove dust buildup from condenser coils on left side underneath freezer. Cleaning condenser coils typically resolves this issue.
But, if clearance is fine and the condenser coils are free from dust and you are still feeling too much exterior heat, you may need to check with a local service tech to determine what else could be causing this issue.
Feel compressor to see if running and warm. If not, most likely thermostat control is bad. If it is running, determine if it runs continuously or if it's clicking on and off every couple minutes. If clicking on and off, replace overload and relay that plugs into side of compressor. If running continuously, there is probably a freon leak on blockage. Replace freezer in latter scenario
When changing the battery it should be a alakline. Also try unplugging the unit and then back in again. Check to see if the sides are getting warm which will indicate the compressor is running. Make sure the compressor is running. Check to see if thermostat is up high enough. The unit may have an electronic board that may be the problem. And lastly, it could have a sealed system problem, like a freon leak. You didn't say how old the unit is.
You said, you have a FFU20FC6AW2 freezer that I have noticed is running continuously. Explains my $400 electric bill.
How old is the freezer?
The thermostat may be faulty. But check out this list first.
If the black tubes running back and forth that carry the freon is under the freezer and behind the plastic grill down near the floor you may want to remove the grill cover and gently run a refrigerator brush across the coils. Ive seen them never cleaned and full of lint and dust 2 inches thick. This is not good for the freezer or any refrigerator too! They need to be clean so air can run across them or they over heat and get hot. Room or outside weather is hot. It is normal for the freezer to work harder under these conditions. Reasons why Freezer may run too much or too long. 1.Freezer had recently been disconnected for a period of time. Freezer requires 4 hours to cool down completely. 2.Large amounts of warm or hot food have been stored recently. Warm food will cause the freezer to run more until the desired temperature is reached. 3.Door is kept open too long or too frequently. Warm air enters the freezer every time the door is opened. Open the door less often.
4.Freezer door may be slightly open. (Freezer is not level. It rocks on the floor when it is moved slightly. This condition can force the cabinet out of square and misaligned the door.Freezer needs to be leveled if this occurs. Floor is uneven or weak. Freezer rocks on the floor when it is moved slightly. Level the floor by using metal or wood shims under the freezer or brace floor supporting the freezer.
5.Temperature control is set too cold. Turn the control knob to a warmer setting. Allow several hours for the temperature to stabilize. 6.Freezer gasket is dirty, worn, cracked, or poorly fitted. Clean or change gasket. Leaks in the door seal will cause freezer to run longer in order to maintain desired temperature.
Let me know what you find Huuum Please remember to leave a rating before you leave.
not necessarily, is it maintaining temp? all food staying frozen? especially ice creams if stored in there. most newer freezers displace the heat generated while cooling the food through copper lines running through sides of unit, helps to cut down on air temp differences between the inside (0 degrees) and outside temp to prevent moisture and possible condensation causing premature rusting of unit
